Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-11-2006, 02:03 PM   #1
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Aluminum Trim Finally Found
After over three years of searching, I finally found this aluminum trim. I saw a picture of it in use in the Winnick designed 75th Anniversary Edition so I called the factory. The young lady that answered the phone in parts was stymied so she went and asked another parts person. He had no idea what I was talking about either. I asked her to look up the online picture I was looking at so she knew what I was referring to. She said she'd get back to me once she found it. It took her a couple of days to locate it and she returned my call. Said I'd need to order a minimum of 12 feet and that I'd have to place my order through a dealer. I called Rick at Oasis in Tucson and explained my story to him along with the part number. Rick called me back a few days later and said my order was being sent out from their shop in Tucson that very afternoon.
It is part number 115345 and the factory has to special order it from a manufacturer as it was only used on a prototype. It runs $2.95 per foot plus shipping with a minimum order of 12 feet. It was exactly what I was looking for. My era of vintage used something very similar but all I could ever find, when I could locate some from a parts trailer, was full of holes and scratched up. This trim provides a nice finished look with an authentic period correct feel.
Still have the bathroom to do, maybe next weekend if it's not over 110 degrees.
FF
ID:	22221   Click image for larger version
ID:	22223   Click image for larger version
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 06-11-2006, 02:06 PM   #2
Profile:  , Minnesota
Images: 59
It looks kind of like this?
http://www.brunnerent.com/Tools/Port...r=5&strMetaTag=
Do you have dimensions? They also have a 12 ft minimum. I got my wheel well trim from them.
Old 06-11-2006, 02:10 PM   #3
flyfshr's Avatar
Phoenix , Arizona
Don ~
That looks like the stuff. The dimensions are the same. The factory probably ordered it from them. I got my wheelwell trim from them too. Suppose I should have reviewed their entire inventory when I was on their webpage. Dooh.
FF
WBCCI/VAC #2699
Air #10
Old 06-11-2006, 03:49 PM   #4
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
I think that's the same trim used as a splash in the vintage Bambi. Anyone know how to bend it?
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com
Old 06-11-2006, 04:12 PM   #5
Images: 59
I estimate you could bend about a 24" radius. More if you anneal it. You would need to keep the long leg "up" so you are crimping the short leg.
Old 06-11-2006, 08:48 PM   #6
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Just fyi...
the VAP (podcast) had this question of David Winwick... there is a link on the VAP.com on that same supplier of the edging.
Marc
Old 06-11-2006, 09:05 PM   #7
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Are the hols pre-drilled in the Airstream material? Looks like the other supplier does have the holes pre-drilled.
I definitely need a couple hundred feet of this for my interior..what's the maximum shipping size? Anyone know?
Uwe
www.area63productions.com
Old 06-11-2006, 09:39 PM   #8
Images: 59
Uwe,
They (Brunner) answer email pretty quick. I don't think the molding comes pre-drilled, and I had them cut the standard 12' lengths into 4' pieces for shipping.
You should email them tomorrow with your questions. Prices are good, and service was excellent.
Old 06-11-2006, 10:09 PM   #9
flyfshr's Avatar
Phoenix , Arizona
Uwe ~
Holes were not pre-drilled from Airstream. Imagine it would be the same thing from Brunner. Mine was shipped in a 7 foot sturdy cardboard tube about 3" in diameter. A couple hundred feet? Really?
FF
WBCCI/VAC #2699
Air #10
Old 06-11-2006, 10:15 PM   #10
uwe
418
uwe's Avatar
Images: 41
Originally Posted by flyfshr
Uwe ~
FF
Not really....I meant that I need quite a bit of it, since I want to trim all the countertops and the bath tub with it.
Uwe
Old 06-12-2006, 12:01 AM   #11
fly2havefun's Avatar
Profile:  1968 26' Overlander
Carbondale , Colorado
Smile Looks Great!
Brad,
The kitchen looks great! I'll have to keep this stuff in mind when I get to re-doing the kitchen. What a great find. Hope it cools off so you can play on your A/S!
I too am curious how you could bend this????
Becky
fly2havefun is offline   Reply With Quote
Old 06-12-2006, 12:04 AM   #12
flyfshr's Avatar
Phoenix , Arizona
Thanks Becky!!
I'm going to bend it with the long side up as previously suggested and plan on bending it around a barrel with a soaked dowel inside the L shape a little at a time. It's fairly soft material without much thickness. We'll see how it goes next weekend. I'll let you all know.
FF
WBCCI/VAC #2699
Air #10
Old 07-20-2006, 04:59 PM   #13
Ledbehind
Profile:  1961 24' Tradewind
Great Falls , Virginia
So.. How did it go?
Brad, I'll be doing the counters this fall & plan on using laminate. Are you also familiar with the aluminum trim for the front edges of the counters? Your work looks great by the way.
Henry
henrydahm is offline   Reply With Quote
Old 07-20-2006, 07:24 PM   #14
flyfshr's Avatar
Phoenix , Arizona
Henry ~
Yup, familiar with that stuff too. It's from Outwater Plastics.
www.outwater.com
I used the 13/16" on the galley cabinet and 5/8" in the bathroom both of these the rippled in the shiney finish. I've been very happy with it.
FF
WBCCI/VAC #2699
Air #10
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 07:19 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
Aluminum underbelly missing Joe C 2003 International 10 11-10-2002 10:41 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 02:56 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 05:15 PM
