Old 01-12-2016, 01:29 PM   #1
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
Question Aluminum faces: Will this work?.
I'm eventually going to take out my bathroom cabinets. The plastic is cracked and the tambour sticks so you can't open the cabinet. I found a great source of sheet aluminum (~0.05") which seems like a good choice for face surfaces. But it's too bendy.
I've been playing around with making an aluminum-wood ply by riveting aluminum sheet to 7/32 plywood and using 1/4" Al channel to cap the edges. It looks good to me and seems be stiff enough to hold up, but also strong and waterproof (if I use the right plywood) . . . also pretty light weight. I think I might even get the plywood to take a bend and then ply the aluminum to fit the bend to reproduce the bend of the original cabinets. Maybe with liquid nails or the equivalent added to make a sort of hybrid metal-wood ply.
Is this workable?
sandgrubber is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
frosted coil up panels to replace tambour cabinet faces colsons Cabinets, Counter Tops & Furnishings 0 05-17-2011 11:50 AM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
