Old 02-26-2011, 01:31 PM   #1
1337stream
worksology's Avatar
2007 27' International CCD FB
Manhattan , Kansas
Aluminum desk top
Over the next couple of weeks I'm going to be replacing one of the twin beds in our 27' International with a custom built desk. Right now I'm leaning towards an aluminum top, probably a nice plywood with a sheet of aluminum glued to the top.
Ideally this sheet of aluminum would match the finish and gloss of the rest of the interior skin. I also like that the Airstream skin is coated with something that resists fingerprints, and that's certainly a requirement for the desk.
Anyone have suggestions for sources or types of aluminum for this purpose? It'll need to measure somewhere around 25"x67". Can I buy something directly from Jackson Center that'll match perfectly, or are there other good sources? Open to alternative ideas, too, like Octolam or Chemetal if they come with recommendations.
Josh
worksology is offline   Reply With Quote
Old 02-26-2011, 01:42 PM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
this is where i bought from: Aircraft supplies aluminum sheet 2024T3 4130 steel tubing Airparts inc - Aircraft construction supplies
based on input from forum.
however, you might consider a countertop from ikea - its aluminum looking formica over particleboard - much cheaper (something like $70 i think).
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 02-26-2011, 01:49 PM   #3
x
XXXX , XXXX
Josh how about something like this. It's HIPS ( high impact poly styrene). looks like brushed aluminium but won't scratch like real aluminium will.
Brushed Alumium Laminate
wasagachris is offline   Reply With Quote
Old 02-26-2011, 02:09 PM   #4
Crazy Montanan in Texas
MrBeast's Avatar
Houston , Texas
I would strongly sugjest you go with stainless steel instead, you will frequently be rubbing your wrists on the aluminum counter edge, and prolonged exposure to aluminum can make you sick.
This is why stainless is prefered for making cookware and countertops.
"When the people fear the government, there is Tyranny; when the government fears the people, there is Liberty." - Thomas Jefferson
MrBeast is offline   Reply With Quote
Old 02-26-2011, 02:11 PM   #5
1337stream
worksology's Avatar
Manhattan , Kansas
I actually started at IKEA, but their metal countertops are not quite long enough (only goes up to 60"). I'd lean towards one of their laminated countertops, but I haven't gotten much longevity out of IKEA wood finishes historically (esp when not using coasters for cups). Still open to that as a cheap alternative.
AirParts is in our neck of the woods, so I've looked at them too. I just don't know which of their handful of aluminum sheeting is most appropriate or how I'd go about finishing them to resist fingerprints. I'll probably give them a call early next week and see what they'd recommend.
Wasagachris, that may be exactly what I need. It looks like that's used mostly in vertical/wall installations, so I'm curious whether it's intended to hold up to the abuse of a desk/countertop? Since they list "durability" as a benefit over aluminum, I'm assuming that's not really an issue.
Thanks for both of your suggestions. I'll dig a little further.
Josh
Old 02-26-2011, 02:24 PM   #6
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Whatever you end up using hope you will post some pics when you get finished. I'm thinking about a 25FB Flying Cloud with twins and doing exactly the same thing.
Al - K4GLU is offline   Reply With Quote
Old 02-26-2011, 03:07 PM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Formica makes a "DecoMetal" in brushed aluminum...it comes in sheets up to 4'x10'. It's made for this sort of thing...and the brushed texture will better match the texture on your trailer than the 2024 from Airparts which is a good match for the mirrored-finish of vintage aluminum, but would easily scratch in a worksurface application.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 02-26-2011, 03:18 PM   #8
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Formica DecoMetal
Josh,
Take a look at the formica aluminum surface material. Comes in polished, brushed and other finishes. You can also purchase the matching edgebanding for what ever surface you choose. Best of all any local cabinet maker can can whip these out in a flash. DecoMetal® by Formica Group -- The Collection -- Formica Limited
If you still want to go with aluminum I get mine at a local sheet metal shop by the pound. They have many different surfaces and thickness to choose from.
Best of luck with the project. Photos of your work are always appreciated.
fltlevel510 is offline   Reply With Quote
Old 02-26-2011, 04:38 PM   #9
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
I made a 33" x 34" dinette table with 3/4" plywood and an aluminum top. Used contact cement for the adhesive. I wanted the look of both metal and wood so I left the plywood edging exposed. I really like it up against the aluminum interior skin, but I didn't realize that exposure to your skin can make you sick! Found the aluminum at a local salvage store. It was inexpensive and they cut it to my size. Good luck.
star kitty is offline   Reply With Quote
Old 02-26-2011, 05:30 PM   #10
steel/aluminum fabricator
2004 22' International CCD
Penticton , British Columbia
I would suggest getting an aluminum looking laminate for several reasons. The airsteam aluminum is laquer coated. Straight untreated aluminum looks great but scratches very easily and will oxidize pretty fast about a year. If you rub Al with you hand ,your hand will turn black from the Al. You can cut Al with any wood blade which is nice but it will dent pretty easily.
Laminate is the way to go trust me. I work with aluminum every day and even though it is great to work with it needs very special attention in its untreated state.
I should add that aluminum will oxidize very fast but can be rebuffed with a 3m scouring pad to look like new (brushed stainless look). But will again oxidize.
I would go laminate for health and maintenance reasons.
zedex is offline   Reply With Quote
Old 02-26-2011, 06:01 PM   #11
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I second the vote for laminate. Most laminates are bullet proof. You can drop stuff on them , stand on them, slide things across them, neglect them and mistreat them and they still look great. Now try that with aluminum and the results will be devastating.
Laminates look great and last a long time, and they are made to be used as counter and table tops
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-26-2011, 07:41 PM   #12
upstateart's Avatar
1994 34' Excella
newark , New York
Metal desktop project
Hi, The husband took one of our twins out of the Tradewind and made a desk set up.... The bunkbed fits above for sleeping purposes. Came out very nice....
ID:	123164   Click image for larger version
ID:	123166   Click image for larger version
upstateart is offline   Reply With Quote
Old 02-26-2011, 09:27 PM   #13
reinergirl's Avatar
Hollis , New Hampshire
Have you looked at wilsonart laminates? Unfortunately none of the "metal look" laminate is rated for horizontal surfaces and needs specialized tools to trim (thats true for all the major brand names I looked at). There are a few laminates from Wilsonart that are kinda cool. Try Luna Shadow pattern / color of Wilsonart HD High Definition Laminate - 1853.
If cost is an issue I had really good luck painting a wooden desk for my son with a hammered metal spay paint. WAY more durable that I thought and very cool looking.
reinergirl is offline   Reply With Quote
Old 02-27-2011, 12:10 AM   #14
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Great idea with the aluminum tables and bunk beds...thanks.
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Is there anything wrong with this polishing? poezlaw Cleaning, Stripping & Polishing 18 02-06-2012 04:35 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 11:38 PM
Aluminum Water Hose Al - K4GLU Fresh Water Systems 14 02-05-2011 06:47 AM
