Old 03-01-2011, 05:37 PM   #29
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I also agree with the stainless idea. Check with restaurant supply houses. They deal in stainless fabrications for commercial dish washer installations and vent hoods.
Vaughan
Old 03-14-2011, 12:45 AM   #30
1337stream
worksology's Avatar
2007 27' International CCD FB
Manhattan , Kansas
After evaluating all of the options, including playing around with some samples of a variety of aluminum alloys, I decided to go with an aluminum desktop as originally planned. I'm pretty optimistic that we'll love it. The runner-up (or Plan B, if it comes to it) was an $80 brushed aluminum laminate countertop from IKEA.
I ended up buying a 6-foot sheet of 3003 aluminum, 0.063" thick, from Airparts, Inc. in Kansas City. I've cut it to size and earlier tonight bonded it to a 3/4" sheet of Baltic Birch plywood (13-ply) with contact cement. Tomorrow I plan to glue a 5"-wide second layer perimeter to the bottom of the desktop to increase the total thickness to 1.5" and 25 plys.
Here are some photos. The desktop measures 59"W x 27"D.
Josh
worksology is offline   Reply With Quote
Old 03-14-2011, 08:10 AM   #31
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by star kitty View Post
I made a 33" x 34" dinette table with 3/4" plywood and an aluminum top. Used contact cement for the adhesive. I wanted the look of both metal and wood so I left the plywood edging exposed. I really like it up against the aluminum interior skin, but I didn't realize that exposure to your skin can make you sick! Found the aluminum at a local salvage store. It was inexpensive and they cut it to my size. Good luck.
I like this look but agree with the other comments about durability. I may consider this with stainless steel on top with the baltic birch underneath.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-14-2011, 10:52 AM   #32
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I watched the sears appliance repair office dumpster everytime I shopped there and nabbed two full length stainless steel refrigerator doors they tossed after cannibalizing seals or some other repairs parts off of.
I cut the molded interior plastic out with a rotozip saw and have two lightweight (foam filled) desk sections waiting to install
Old 03-24-2011, 07:51 PM   #33
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Similar solutions.
Josh,
Same direction I'm heading on my 1970 Safari. Aluminum over the ply.
Stiking with the "salvage" parts idea, the dinette table will be 24 by 48 inches up front.
Wabbiteer,
great idea...
Wanted: 18w X 22h side window, 70 AS.
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 06-30-2011, 05:47 AM   #34
1966 22' Safari
Seven Valleys , Pennsylvania
I'm wayyyy late on this, but anyone dead set on aluminum could finish it like we did our front door. It is steel but did the same on aluminum backsplash. Just use an small grinder with a Roloc disc to get whatever design you want to use then we did a candy color & clearcoat. The clearcoat will damage as paint would, but it will hide your scratches on the aluminum! It's hard to tell from the photo but there are flames in the center. The whole thing has a 3-D effect.
scarylarry is offline   Reply With Quote
Is there anything wrong with this polishing? poezlaw Cleaning, Stripping & Polishing 18 02-06-2012 03:35 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
Aluminum Water Hose Al - K4GLU Fresh Water Systems 14 02-05-2011 05:47 AM
