This stuff is a resin with aluminum shavings embedded in it! Is that cool or what? You can get it in two forms: one has the shavings visible below the surface, and the other has been sanded down to expose the edges of the shavings.
I didn't find a weight listed on the Web site. Did anyone else figure out how heavy it is? I would guess that a half-inch of resin would be pretty hefty.
__________________ Of course I'm an elitist. Look around you.
for 900 bucks plus change -what if- you made a mold filled it with resin then sprinkled olympic rivets in it and whatever other airstream related bits and pieces in it?
and also not install a backing on it so it was translucent? you could light it from below!
just an idea if you are gonna blow a grand on a counter top!
john
you call them ferrets, i call them weasels.
Our son, the custom cabinet maker, made a resin bar top that was really great looking. He used a beautiful piece of wood for the bottom, put 3/4" sides on it and poured in the resin. He then immediately put a handful of shiney clean change in it to give it interest. All the change he used was dated the year he built it.
Anything's possible... and now that you have given me that idea... I'll run it by my son. I love the rivet idea!
Beth
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Living in the belly of the whale is cool"
I think their website says the stuff is 25% aluminum by weight, but I'll bet it's still heavy as hell like Corian or any other plastic material.
The price ($39/sf for the raw material) is probably comparable to other solid-surface materials.
Speaking of illuminating a countertop from below, this stuff may be somewhat translucent even if it is loaded with aluminum shavings. Somebody needs to be our group guinea pig!
Just make sure that any metals you use in are completely encapsulated in resin. You sure wouldn't want acids leaching heavy metals into your food while you're making dinner!
Roger
__________________ AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein 1994 Airstream B190 & 2006 Bigfoot 25B25RQ
