02-05-2010, 03:59 PM
#41
1972 23' Safari
Houston
Table Counter Trim
So I ordered the edge molding from VTS, paid for the 8' tube and it finally showed up, except the tube was empty. The plastic taped over ends were gone on one end and hanging by a thread on the other. So thanks UPS.
VTS is sending out another round so we'll see this time what happens.
02-05-2010, 04:15 PM
#42
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
That's nice...
Uh...have you considered an alternate moulding? You obviously are not meant to get this one...OMG! I'm sorry, but I had a good laugh at your expense...thanks, I needed that!
Shari
02-05-2010, 11:15 PM
#43
1972 23' Safari
Houston
Metal Trim
Someday I will post photos of the finished trim.
02-06-2010, 08:18 AM
#44
1956 22' Safari
Conifer/Evergreen
Can't wait to see it after all this!
Shari
03-18-2013, 08:19 AM
#45
1999 19' Bambi
Cape Canaveral
RichHog,
I am doing research for a remodel and stumbled upon this thread.
Did you ever finish this project?
I want to know if that A-813 easily bends?
Thanks!
Luc
03-19-2013, 07:23 AM
#46
1972 23' Safari
Houston
I never could get the local Home Depot to order it as they didn't stock it here. Then looked at local hardware stores and gave up on it. I wound up using a black T-molding around the table edge that looked nice when finished. There were several people that had used the A-813 on their tables/counters that looked great.
I still have lots of the t-molding trim if you decide you want it.
03-19-2013, 12:30 PM
#47
2006 19' Safari SE
Tucson
Originally Posted by Luc
RichHog,
Thanks!
Luc
A-813 does bend easily with just hand pressure... We used it on our counter and table top...see post #19 above. We cut it to size with a hack saw, then screwed one end into place, and bent it to shape around the curved edge of the counter and table.
We got our aluminum trim at Ace Hardware...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
05-06-2013, 05:45 AM
#48
1999 19' Bambi
Cape Canaveral
Getting ready to do it but have one final question. Did you use the screws provided or did you use something more decorative? The screws that came with the trim seem dull to me.
05-07-2013, 02:18 AM
#49
2006 19' Safari SE
Tucson
We used the screws that came with the trim, but you can use any similar screws you wish.
AirForums #21900
PastPrez, 4CU/WBCCI
