Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-30-2003, 10:28 AM   #1
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
aluminum composite countertop repair?
Hi - We recently purchased a 1977 Argosy minuet 6 metre and are rehabbing the interior. The original countertops (orange) are delaminating and damaged and will need to be replaced.
The laminate is mounted on is a composite aluminum sheet - similar to the floor of this trailer. Any thoughts about saving the countertop base or simply replacing it with plywood?
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 09-30-2003, 10:38 AM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Save it!
The weight penalty for the plywood is not much, but it cuts into your usable weight. If the laminate is loose then once you remove the countertop you should be able to pull it the rest of the way off. It may require some heat, or being left in the sun for a few hours to get the still stuck glue to release. You can hand sand the old glue off with some 150 grit paper and relaminate the original top.
In my current MH I replaced the countertop and used new wood, but I have a higher useable weight so a few pounds of wood was not a big deal. I did however need to pull the laminate off to recover the edge trim. Oddly enough it was an aluminum band I guess they wanted to keep the edge thin. The sun did the trick and I was able to get a thin putty knife under the laminate and pop it off. They seemed to use a spray on system for the contact cement and with age it will release. In the case of relamination I would use roll on cement to help fill the roughed up base.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Aluminum floors? Janet All Argosy Trailers 9 10-28-2009 09:32 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
Durafix aluminum repair 83Excella General Repair Forum 1 03-22-2003 08:03 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
