Old 12-23-2012, 10:32 AM   #15
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
I just visited Airparts. Nice selection. Glad to see they can ship. I've just ordered a catalog for now. I've got some aluminum on hand right now that I can start practicing with.
A couple questions though, Frank: 1) Do you have a good method for making the aluminum flat again once you get the roll? We do this to steel at work but of course it's done with multi-thousand dollar straightener machines. I'm assuming in one's shop or garage there's a simpler and cheaper method? Then again, you've probably invested in a metal brake and roller. 2) what thickness would you recommend for building cabinet doors? I plan to hem the edges so it has to be very bendable and I also plan to *try* to roll the doors into the Airstream arc of the 70's cabinets. But, more importantly is that when the door is pulled open that it does not flex too much.
WineStream is offline   Reply With Quote
Old 12-23-2012, 03:31 PM   #16
Baltimore , Maryland
Not to be a smart ask, but the answer to #1 is take it out of the box. It is aluminum, not steel.
To the second question I would use .040. To make it rigid, you will need to make some rather complex back bends. You might consider a small angle or bar as an internal support. I am not exactly sure of the design, so kind of hard to advise on this this.
Old 12-23-2012, 04:03 PM   #17
WineStream's Avatar
2005 30' Safari
Images: 24
I never figured aluminum rolled into a tube that is ship-able size would spring back to flat!
Old 12-23-2012, 07:28 PM   #18
the box is 18"x 18"x48". If you buy 5052 it will hold a little curve, but the rest will go flat right away.
