Old 01-05-2010, 07:30 PM   #1
billiards's Avatar
rochester , Minnesota
advice/closet hanger rod
2005 safari 25 ft. ......left closet rod has anti slide plastic wrapping...(some one had a nightmare inventing it)anyway i am trying to remove the rod which is incased by wood bracket w/whole to support the beast on wall of closet...it seems that the rod not only goes through the bracket but throught the wall its self.....can this be possible? if so i guess i will just take a small dremel drill will cutting wheel and cut along the plastic ribbed cover....help....thanks a million
billiards is offline   Reply With Quote
Old 01-05-2010, 07:35 PM   #2
2009 25' SS International
Pasadena , California
i have an 07, not sure if it changed... just unscrew the wood plates holding the rod in place... carefull the shelve on top is beeing held by these too (and some screws from that shelve go into those plates)... remove rod and put plates back in place... done
flmgrip is offline   Reply With Quote
Old 01-06-2010, 12:25 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't understand why you want to remove the rod or the plastic cover. I use very thick plastic coat hangers in mine. Wire hangers and wooden hangers with wire hooks don't work well with the ribbed plastic rod. I don't like the thin plastic hangers either.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-06-2010, 08:01 PM   #4
billiards's Avatar
for future ref.......the metal hanger rod does not only go through the wood mounting brackets, it also goes through the wall....therefore there is no removing the rod as it must have been assembled b-4 placement in trailer....(i did infact cut the plastic ribbed coating to get results i wanted)....thanks to all
Old 01-06-2010, 08:34 PM   #5
copy that... on my 09' 25' CCD i was able to do as i descibed...
Old 01-06-2010, 08:35 PM   #6
i removed mine to put more shelving in...
Old 01-06-2010, 08:41 PM   #7
Salem , Oregon
Images: 18
Hi, glad to hear you got done what you wanted. Can you post pictures and explain why you wanted the ribbed plastic removed. Like I said, mine works best with very thick plastic coat hangers.
Hi, that makes sense; do you have pictures of the shelves you installed?
2005 Safari 25-B
Old 01-07-2010, 09:41 AM   #8
billiards's Avatar
the reason for removing the ribbed plastic was it is difficult to slide the hangers and clothes to one side for easy removing particular hanger and its clolthing....the groves hold the hanger and there is no sliding if that works for ya, i just didnt like it or think much of the idea. (i must be getting short on tolerance) thanks for all the interest and help.
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 06:03 PM
Anode Rod SilverCabin Water Heaters, Filters & Pumps 9 02-17-2009 11:23 AM
Hott Rod trailermom Water Heaters, Filters & Pumps 0 10-21-2006 08:23 AM
Use of Hott Rod? desidou Water Heaters, Filters & Pumps 1 06-07-2005 08:40 AM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 12:46 PM
