09-30-2012, 04:11 PM
2013 25' Flying Cloud
ARTHUR
Adjusting cabinet hinges
What is the procedure for adjusting and tightening (and keeping tight) these infernal cabinet hinges?
09-30-2012, 05:05 PM
2005 25' International CCD
Lilburn
, Georgia
The back screw adjusts the in and out. The middle screw adjusts the up and down. The front screw adjusts the right and left. Post a pic of the hinge if you meed more info. We run a cabinet shop.
My grand parents are buried in Arthur but havent ever been there. My dad and brothers take care of the cemetary.
09-30-2012, 06:24 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Procedure for adjusting newer cabinet hinges.
They put the procedure in the October 2012 Blue Beret on page 40. They just posted that issue to the web. Here is the link. Blue Beret Online Magazine-Home
09-30-2012, 06:47 PM
ARTHUR
Thanks. But.........it leaves unanswered my main question. It says that the three screws DO NOT TIGHTEN THE HINGE......so what does? He asked. I don't know about you, but constantly tinkering with these little gems is not how I like to spend my time. Surely there's a way to keep them tight. (besides not traveling and not opening the doors)
09-30-2012, 06:50 PM
ARTHUR
Originally Posted by jupitorj
My grand parents are buried in Arthur but havent ever been there. My dad and brothers take care of the cemetery.
Small world!
09-30-2012, 07:30 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
I think you may be having trouble with the screws that hold it to the cabinet and door. They have a habit of working themselves out and making the holes bigger. You can get a filler that fills the hole and then you put the screw back in. I know Super Glue has a filler for that.
The screws would be the ones that don't adjust it.
Gene
10-01-2012, 08:23 AM
ARTHUR
Gene
No. It's the hinge mechanism itself that jiggles out of adjustment.
10-01-2012, 08:40 AM
Lilburn
, Georgia
These hinges consist of two parts. The hinge and the mounting plate. The mounting plate is screwed to the cabinet. And the hinge is screwed to the door. Those screws can come loose, though not often. The hinge clips to the plate without screws (some older hinges do screw to the plate, but not the ones on my older '05 trailer so I wouldn't think yours would). The three screws in the hinge are for adjustment only. I haven't had them get loose unless they are over loosened as part of the adjustment. Perhaps some locktite on the adjustment screws is needed. Locktite will make it more difficult to adjust in the future, but usually not impossible. You would just have to break the 'glue' hold. In a worst case you would have to get a new hinge.
10-01-2012, 08:52 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Loctite is available in in a number of grade strengths. Talk to NAPA or other sources to pick the one that provides just enough strength. So grades are so strong they can replace welding is specific applications.
10-06-2012, 02:24 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
We have a 2004 Safari and have hinges failing all over. Right now all three hinges on the wardrobe are off. It almost appears to look like the bases are worn so that the clamp on the adjusting part won't stay put. Hopefully I am just doing something wrong that some one can help me with.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
10-06-2012, 04:36 PM
Lilburn
, Georgia
It sounds like you should replace them if they are worn. If you post a picture I can probably tell you where you can get them.
10-06-2012, 04:59 PM
Salem
, Oregon
Hi, my cabinet hinges kept coming loose, so I used blue Loc-tite on them. They are a real pain especially on my large [three hinge] closet door.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
04-06-2017, 06:17 PM
2002 27' Safari
Churchville
, Maryland
My 2003 28' Safari has bad wardrobe hinges that were made by Grass. I would like to know where to get replacements. CabinetParts.com sent me what they claimed to be replacements but they did not fit correctly. These hinges require adjustment after 300 miles of interstate. I see no way of dealing with the worn out hinges except a continuous hinge replacement. Would appreciate photos from anyone who has made this change.
04-06-2017, 06:32 PM
Granbury
If the hinge is coming undone from the plate that mounts to the cabinet then some have suggested using wire ties to hold the two parts together.
These euro hidden hinges are used in many cabinet applications. The cup size and offset are the only requirement to know for replacement. You will need to replace the door part of the hinge and the cabinet part...which may require new screw locations.
If you have a screw stripped...put some woodworking glue and a toothpick in the hole. break the toothpick off flush with the hole and let the glue dry...reinstall the screw being careful not to tighten past snug maybe a tad bit more but do not over do it.
11-09-2018, 06:32 AM
2005 28' Safari S/O
Bountiful
, UT
Yes, I realize this post is 18 months dead, but good information is never dead. As a former cabinet shop supervisor, I can tell you the Blum hinge plates and hinges were our first and only choice. It sounds like AS is using the small #6 or #8 wood screws to secure the plates. Blum has a base plate with 5mm screws and these rarely back out. We just bought our AS so I will have a look at the hinge combination they use, and I will switch to the Blum system if its not already in the trailer. The fun begins.
