Old 06-19-2013, 08:50 AM   #1
HAschner's Avatar
2012 20' Flying Cloud
Richardson , Texas
Adding corner shelf in 20 footer
We have a new 20 foot Bambi and would like to add a corner storage shelf or something similar between the two kitchen cabinets. This seems like a wasted space area to me. The shelf would be for light-weight bulky items like paper towels, chip bags, etc.
The rounded corner and uneven shape of the area is the challenge. Has anyone else added some storage in this corner?
--Thanks in advance for your ideas.
Henry & Judy Aschner
New owners since 2013!
__________________________________________
Henry - "experience is what you get..... right after you need it."
HAschner is offline   Reply With Quote
Old 06-19-2013, 09:06 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We just put a paper towel holder vertically on the side of the rear cabinet
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 06-19-2013, 09:17 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Make up a template using thin MDF or cardboard. After you have that to a good fit transfer the shape to your final material. Mounting blocks can be screwed to the existing cabinets and the new panel secured to those. Any competent wood worker should be able to make a shelf for you if you do not wish to tackle the project yourself.
MICHAEL
Old 06-19-2013, 04:00 PM   #4
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
A major challenge (as Michael noted) is coping with the curvature of the interior of your trailer. If you take a straightedge and run it (carefully so as not to scratch anything), you're going to find that there's hardly a straight surface if you go vertically -- so the template is really critical to get something to fit well. You'll notice that the factory really does a good job at this. They should, right?
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-19-2013, 04:22 PM   #5
HAschner's Avatar
Richardson , Texas
I wondered if there was a reason they do not include a shelf from the factory - like torque between the two cabinets while driving down the road. Have measured out the space and it is an odd shape. Before I cut this out myself, I did wonder if someone else has tackled the project from a creative angle that I have not thought of yet.
Old 06-20-2013, 07:47 AM   #6
AWCHIEF's Avatar
Images: 33
I would imagine that it is a cost cutting measure. It is typical of most manufacturing these days. Make a product as cheap as possible and sell for as much as the market will handle. There really is nothing magic about adding a shelf. Simple measure, cut and screw should do the trick. If you are worried about an exact fit, cut over sized and trim to fit. I have built a number of cabinets and shelves for boats and the process is the same when dealing with odd angles and curved surfaces.
MICHAEL
