Old 07-02-2013, 12:57 PM   #1
withidl's Avatar
2002 31' Classic
Houston , Texas
A Solution Looking For a Problem
Shortly after I purchased my 2002 ASCL 31’ I discovered that the living area bi-fold table had a minor imperfection (raised area at hinges); so I called Jackson Center and they said no problem and sent me another, which when received was for a “Classic”, not a “Limited”, and thus not solid oak. So again I called Jackson Center, advised of the error, and they then sent me the correct solid oak one. I offered to return both of them but they declined as they did not want to incur the return shipping.
Now, not being one to discard something of value, I put both in my attic, where they’ve festered for the last 11+ years…………..but, THEY HAVE ALWAYS BEEN ON MY MIND! A solution looking for a problem.
I have the twin bed with night table configuration. This doesn’t allow for sitting on the side of the bed and eating a meal, playing games, etc. because the night table is not “in front of you”. So, with the bi-fold table weighing heavily on my mind all these years the solution finally realized the problem, i.e. just mount the bi-fold table on top of the night table, pull out the extension, open the table and problem is solved.
The modifications that had to be made were as follows:
  • Had to position the bi-fold table to clear the 12 volt outlet over the night table.
  • Had to determine the reference of the sliding extension. This resulted in removal and slightly repositioning it under the table.
  • Had to fabricate a cosmetic oak trim cover panel for the bi-fold table exposed hinges. This was done with oak trim I had pulled out of the trash while at Jackson Center several years ago; you know something of value; one man’s trash is another man’s treasure. Anyway, I mirrored the frontal slide shape and routed out the trim panel where the hinges protrude, then inlaid 8 very small super magnets in the cover such that they are directly over the Phillips screws which hold the hinges in place, that gave me a “snap on” fit.
  • Had to fabricate cosmetic covers for the sides of the slide mechanism from some more of that trash.
  • Had to determine how to attach the bi-fold table to the top of the night table. This was done using silicone rubber; being very careful not to allow it to interfere with the pull out slide (I used silicone rubber as I didn’t want to damage the night table top if I was to ever remove the bi-fold top).
Now if I could just figure out what to do with the “Classic” (non solid oak) bi-fold table; it may take another 11+ years; I’ll work on it.
Following are photos of the solution for anyone with this problem:
Name:	Bi-Fold Night Table1-20130702.jpg
ID:	189976   Click image for larger version
Name:	Bi-Fold Night Table2-20130702.jpg
Name:	Bi-Fold Night Table3-20130702.jpg
ID:	189978   Click image for larger version
Name:	Bi-Fold Night Table4-20130702.jpg
Name:	Bi-Fold Night Table5-20130702.jpg
ID:	189980   Click image for larger version
Name:	Bi-Fold Night Table6-20130702.jpg
Name:	Bi-Fold Night Table7-20130702.jpg
ID:	189982   Click image for larger version
Name:	Bi-Fold Night Table8-20130702.jpg
Name:	Bi-Fold Night Table9-20130702.jpg
withidl is offline   Reply With Quote
Old 07-02-2013, 04:01 PM   #2
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
What a terrific option for your trailer. Beautiful craftsmanship and oak is NOT the easiest of hardwoods to work with. Congratulations!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-02-2013, 04:29 PM   #3
richinny's Avatar
2011 34' Classic
i expect to see this on upcoming models! great job :-)
Ricky
Old 07-02-2013, 07:00 PM   #4
Rollster's Avatar
Saint Augustine , Florida
Love it!!
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 07-02-2013, 10:40 PM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
Maybe I could leach some "royalty" from Airstream ................ Its a thought.
Old 07-04-2013, 01:41 AM   #6
richinny's Avatar
2011 34' Classic
royalty, hummmm, maybe but it might be offset by the royalties on the original table ;-)
Ricky
Old 07-04-2013, 08:56 AM   #7
withidl's Avatar
2002 31' Classic
Houston , Texas
Drats; foiled again!
Old 07-04-2013, 09:06 AM   #8
richinny's Avatar
2011 34' Classic
don't feel bad, you can always say you did it first!
Ricky
