Old 04-29-2010, 10:43 AM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
A Corian upgrade for countertops
Greetings,
I am in the midst of a Corian upgrade for the 2007 Safari FB To date, I have had Lowe's order and cut Corian tops and integrated sinks for all counters and the table.
This includes 1.5" backsplashes all over to replace the caulking (which was coming apart).
I have carefully removed (torn out) the existing laminates. They were not too cool and the laminate fronts were coming off. Hey, life is short.
Tear out was not difficult, but don't do it if you can't stretch and crouch. It took 3 hours. Lowes charges $300 for tearout, so I got paid $100/hour. Better than consulting with the military!
The Corian was $2000, installed.
Airstream is very creative about some hidden screws, but I only had to rip one out in the bathroom.
I checked with Airstream and my dealer on the installation.
* thickness will be 1/4 more than the existing. for strength.
* Can use existing screws in table. I replaced the front folding puny leg with a solid
marine aluminum center leg (still removable).
* They can be glued on, but should not be glued to the wall.
* Existing plumbing will likely work (but of course there will be some problem)
* The easiest removal was the stove. But installing it again with the added 1/4"
will require a spacer and some rear support blocks to be installed to avoid stressing
the Corian.
I was quite concerned about the kind of installer they might use, but he turned out to be a long-
term countertop guy that lost out in the housing sink, so he was excellent and available.
But he had to scratch his head about a few corners and esp. the fold up counter.
Had to shrink the size of the kitchen sink because of spacing and availability of sinks.
However, the wife approves, because she likes the increased counter space and
can still get our pots in the new one.
After all that excitement, it won't be installed til next week. I will post pictures and more comments.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 04-29-2010, 10:52 AM   #2
_
lookin' 4ward 2 da pix!
Originally Posted by hshovic View Post
...* thickness will be 1/4 more than the existing. for strength...
does this mean 1/4 INCH thicker than the old laminate stuff or the a/s spec'd corian?
have u calculated how much extra this will weigh (or is it less than the glued stuff)?
i've had no issues with strength of the rv grade corian, it's been great.
IF using corian for the dining table (mine is plank hickory) a tad thicker might be a good idea.
no doubt saying GOODBYE to the poorly glued edges will be nice.
color?
cheers
2air'
Old 04-29-2010, 11:51 AM   #3
1986 25' Sovereign
Plant City , Florida
I am about to undertake the exact same project. Good luck and look foward to pictures.
ck21084 is offline   Reply With Quote
Old 04-29-2010, 12:15 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Looking forward to pics! We love pics around here.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-29-2010, 01:28 PM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Sounds like an exciting project. Please take detailed pictures. Pictures will help with us DIY types out here. Especially where the top meets the walls etc.....
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-29-2010, 03:58 PM   #6
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
This sounds like quite the undertaking! Looking forward to seeing pictures, and hopefully we'll see the finished product at the Hands-across-the-border rally in September.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 05-15-2010, 09:23 PM   #7
hshovic's Avatar
Bozeman , Montana
Images: 20
And the Corian is in....
It took two days for the Corian people to install. Since they worked for Lowes on contract by sq. ft., they underestimated the time to make all those corners and install it, but that is business I guess.
Installed fine, they had to change the screw lengths for the table because of the Corian. They glued with silicone. They charged me extra for installing the stove. Had to put some steel reflective tape to protect the stove.
They had to attach blocks for the stove screws, since they could not screw directly into the countertop as was done before. They had to block up the stove to account for the extra 1/4 inch.
Sink reached down further. See the undercounter kitchen picture for the change (the white pvc piece). I had some plumbing problems as predicted. I had to cut into the main plumbing (see the kitchen plumbing picture), to lower the trap since the sink was two inches deeper. The backsplash had to be cut down to stay under the window. It is tacked to the wall with spots of silicone. Notice the wall is not perfectly flat, so the backsplash looks a bit wavy. Not a problem, though, since it is not too visible.
Note the nice job of blending the corners on the flip up counter (picture of kitchen closeup). In the bathroom the sink was off just enough so the original plumbing did not match. See the picture, and you can see the sink drain is a bit off. After running all over town to find an extender, I gave up, cut the trap off and silicone glued it. Something for the next owner to curse me about....
It looks and feels good. However, it is about twice as heavy. So the flip-up counter may be a problem in terms of banging around. I found a cabinet clip to secure it, but one might also use a bungie around the front. Note the heavy duty marine table leg. It is detachable so the bed can still be made (picture of table). The installers had to glue yet another 1/4 inch under the back brackets to make the table level.
I also purchased new fixtures. Why? I don't know. the wife liked it I guess. The smaller spigot is for filtered water.
So we will see. Our first trip is in June for a month. Hopefully no leaks, but I am ready with the silicone.
What would I do different? Nothing I think. So far it is just fine. But hard to say in the long run. Hopefully it is not so heavy it rips out the plumbing or some other disaster.
ID:	102577   Click image for larger version
ID:	102579   Click image for larger version
ID:	102581   Click image for larger version
ID:	102583   Click image for larger version
ID:	102585   Click image for larger version
Hank
Old 05-15-2010, 09:56 PM   #8
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
looks great!!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 05-15-2010, 11:24 PM   #9
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
May I ask how much weight was added to your trailer?
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 05-16-2010, 04:46 PM   #10
bolerama's Avatar
Images: 30
What a lovely choice! It looks amazing!
Lisa
Lisa and Paul
Old 05-16-2010, 05:42 PM   #11
Shiny metal's Avatar
2008 25' Safari SS SE
Livermore , California
Thumbs up Great job!
Looks great. I have a few changes in mindfor my trailer. New counter tops is at the top of the list.
Shiny metal is offline   Reply With Quote
Old 05-16-2010, 05:49 PM   #12
OO , OO
Send a message via Skype™ to cruiser54
Great work! But: how is this with the weight? Are these only thin records them were stuck, so not massively?
Greeting Werner
cruiser54 is offline   Reply With Quote
Old 05-16-2010, 06:17 PM   #13
OO , OO
In Europe the load may be in the shaft only about 170 - 220 pound.The new axle (with crowd brake) remains at the same place like the old one. This is optically nicer. However, the axle is shifted 18.5 inch, to the back. I have an Excel table where I all weights must calculate...I hope, one understands my words, but the computer is to blame for it!
Old 05-16-2010, 08:10 PM   #14
_
look great hank!
that dining table IS substantial, are the oem wall hooks/hangers being used?
how thick is the C ?
looks to be an INCH or so, maybe more?
the RV stuff a/s uses (and other rv makers) is about 3/8 th of an inch.
ends and edges are made to look THICKER with thin strips along the perimeter...
this makes a huge difference in terms of extra weigh,
the thin stuff is ~ the same as wood or laminates.
and hold up just fine to use and travel.
cheers
2air'
Corian Counter Tops Rod Pease Cabinets, Counter Tops & Furnishings 27 04-22-2015 04:01 PM
Corian Counter Top 6thChief Cabinets, Counter Tops & Furnishings 8 04-23-2012 07:09 AM
Countertops...Again! Steve Heywood 1997 -2001 Excella 13 05-14-2005 01:34 PM
Corian Countertops??? Steve Heywood 1997 -2001 Excella 11 04-15-2005 08:12 AM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 07:31 AM
