Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-28-2014, 07:46 PM   #1
1996 30' Excella
Spruce Grove , Alberta
'96 Classic Rear Bedroom Cabinet Separation
We have a 1996 Classic Excella 1000. We appear to be experiencing some separation of the rear bedroom cabinetry from the street side wall. It is unclear to me whether or not the upper wall brackets were ever fastened to the wall (no screws or rivets now) and there is a 1/2 inch gap between the lower wall fasteners (screws) and the wall. Is flexing of the wall the problem and should these fastenings be connected and if so what method is best?
Thanks in advance for your thoughts.
Garry Russ is offline   Reply With Quote
Old 07-28-2014, 07:58 PM   #2
dznf0g's Avatar
2007 30' Classic
Oswego , Illinois
Boy, Gary, Pictures might help, but I got a feeling if there is really a lot of flexing going on back there, we wouldn't be able to tell without a thorough look over, under, inside and out. Any other signs of things moving about?
-Rich-
Old 07-30-2014, 09:26 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Get some pics! What size is the AS?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-20-2014, 07:26 PM   #4
MtnCamper07's Avatar
1993 30' Excella
Salida , Colorado
If I understand you correctly, and there is no hanger or mount on which the upper side of the cabinets are attached to, then the only thing holding the cabinets to the wall would be the lower wall hanger or screws, is that right? If so, then the weight of the cabinets themselves would cause the movement that you described (even without the weight of whatever was inside the cabinets). I can't be sure that this is what's happening but it sounds like this is part of your problem.
NB
MtnCamper07 is offline   Reply With Quote
1998 airstream safari excella classic 34' rear bedroom 1/2 ton tow rv nr eBay Watch Airstreams on eBay 0 06-16-2013 05:20 PM
I have a strong mildew smell coming into the rear Bedroom of my 34 foot classic. Emh142 General Repair Forum 8 04-03-2012 06:26 AM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
Overhead Cabinet Separation '67 Safari airdrmr Cabinets, Counter Tops & Furnishings 23 09-12-2007 12:38 PM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
