Old 08-29-2019, 09:02 AM   #21
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
Originally Posted by JohnnyAustin View Post
So I was inspired by this thread and decided to use 80/20 aluminum to frame my interior. Great stuff. The dinette was a pain because of all the non-right angles. I’m hoping the rest goes a bit quicker.
Wowzers. Looking really good.
How deep are your bench seats, and how high are the backs?
What is the bench back angle offset?
What are you doing with the areas beneath the seats?
I am installing the drawers this week, and am selecting materials for drawer fronts and latches.
Yes, the other cabinet went faster, once you design in specific locations for batteries, chargers drawers, wiring, etc. The area over the wheel well and up against the refrigerator was also a bit tricky, and it required a couple of "tries".
As you found, getting the heights correct below the windows is critical, especialloy when adding a counter top.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 08-29-2019, 09:18 AM   #22
gklott's Avatar
2004 30' Classic
Images: 86
Originally Posted by Disable View Post
Gklott, amazing work! I've tagged this material as what I would like to build most of my stuff. How did you mount everything to the walls?
Thanks. Continues to be a fun and rewarding project.
I primarily use the floor to anchor in place. For bolting to floor, I use a #10 stainless screw via a 80/20 parts mainly 4265, plus occasionally 4260, 4286, 4266, 4175 or 4113 where appropriate. For bolting to wall, I use a #10 stainless screw and part 4265.
I use 4265 to attach the counter tops, seat backs, etc. since it allows for a little adjustment.
We all quickly discover the floor isn't flat, the walls are not straight, and there are few, if any, right angles anywhere in an Airstream (as built). :-)
73/gus
2004 30ft. Classic
Old 08-30-2019, 08:32 AM   #23
1988 29' Excella
Austin , TX
73/gus
Seat backs are 15 inches high and seats are 22 inches deep. There will be 4 inch cushions. The seats recline at around a 7 degree angle. Hardest part were the corners where I had to deal with the 45 degree angle plus reclining seat. I built a trapezoidal frame out of angle aluminum and bent some flat bar to attach to frame. It came out well but was slow going to get everything right.
I had some mistakes when I started. It took a few tries to get the counter bore done well enough for the anchor fasteners. Itís easy to cut now but I had to learn to secure everything very well. It also took a bit of learning where various fasteners will work or not. For instance, you donít want to cut an access hole through a solid decorative facing.
I used 1 inch pieces of 1 1/2 inch angled aluminum to secure in the corners. A cheap solution that worked well.
John
JohnnyAustin is offline   Reply With Quote
Old 08-30-2019, 09:05 AM   #24
1988 29' Excella
Austin , TX
Oh, and then thereís the dumb stuff. My plan was to insert 1/4 inch plywood panels into the tracks to close up the bottom. I even cut one panel before I realized that once the panels are installed you canít get to the screw/connectors to tighten them or once you tighten the screws/connectors you canít get the panels in place. Doh!!!
BTW. Iím just using plywood for seats and backs. Seats will just rest in place so I will be able to lift them out for access. I putting a drawer in the seat by the door.
Old 09-15-2019, 12:40 PM   #25
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
This is a wonderful thread. Excellent job on the build!
We toured the 80/20 facility and we were impressed. We wanted to use it to build twin beds in our Chinook motorhome. Unfortunately, it was cost prohibitive here in Canada. We love the look, weight, ease of installation.
Thanks for making this thread.
Lisa and Paul
https://atomicpod.wordpress.com
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
Full-time since July 31, 2017
bolerama is offline   Reply With Quote
Old 12-01-2019, 09:14 PM   #26
2014 23' FB International
Wichita , Kansas
23FB Queen to Twin Conversion Using 80/20 Extruded Aluminum Frames
We converted our 2014 International Serenity 23FB bedroom from a queen bed to two 34Ē x 80Ē twin beds using 80/20 extruded aluminum. Pictures 1, 2, and 3 show the exterior panels mounted to 80/20 frames. See Picture 4 for one of the frames. I placed the project details on The 23 FB Forum at Post 1618 here: http://www.airforums.com/forums/f142...166374-81.html if you are interested in the details.
Iím happy to answer questions posted to The 23 FB Forum.
Name:	Post Picture 1.jpg
ID:	357129   Click image for larger version
Name:	Post Picture 2.jpg
Name:	Post Picture 3.jpg
ID:	357131   Click image for larger version
Name:	Post Picture 4.jpg
SimRunner is offline   Reply With Quote
Old 12-01-2019, 10:40 PM   #27
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Slim that looks so good. Clean, and not sensitive to weathering under heat and water. Just reread the thread and several sprinter build outs.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 12-02-2019, 07:15 PM   #28
Wichita , Kansas
Thank you, Hittenstiehl. I used the 10 Series 1" based profiles. Below is what the frame in Picture 4 above looks like covered with wood/laminate panels.
Name:	Post Picture 7.jpg
1970 Silver Streak interior aluminum cabinets Sinibl Vintage Kin 17 03-26-2019 10:49 AM
2006 Dinette Benches Barnbridge Airstream Classifieds 0 02-22-2018 06:52 AM
Upholstering couch and benches in 2005 25 ft. Janet Mc Upholstery, Blinds, Walls & Interior Finishes 11 12-01-2015 01:44 PM
Phase 2 has started, new kitchen cabinets and front underbelly, floor and restoration aquinob General Interior Topics 67 02-05-2015 04:34 AM
Need plans for 1960 benches and table!!! artemis917 1959-69 Tradewind 0 09-23-2009 09:21 PM
