Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-13-2009, 07:18 AM   #1
Profile:  1973 27' Overlander
Loganville , Georgia
73 Overlander bathroom cabinet mirror removal / Help?
We broke the frame to the bathroom mirror. The mirror is cracked and hanging down over the sink. How do you remove the mirror which has the two lights on each side. It is in the rear bathroom of my 73 overlander. It is a cabinet mirror. Ca I just remove the mirror frame which has the mirror and the two lights. or does the whole cabinet need to come out. I really do not know where to start.
I have a replacement lined up. I am trading parts with another member who is redesigning his bathroom.
Brian & Adrienne
Lothlorian is online now   Reply With Quote
Old 07-13-2009, 08:00 AM   #2
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
You can remove the mirror and light assembly without having to remove the whole cabinet, but you will need another person to help you. Have one person pull open the mirror assembly as far is it will go. At the top of either end you will see an L bracket. Drill out the rivets holding the L bracket in on either side. After that, disconnect the wiring for the lights. Once that's done the assembly should lift out.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 07-13-2009, 08:09 AM   #3
Mello Mike:
Thank you very much. I will do that.
Brian
Brian & Adrienne
Mirror-Glass WC Cabinet Doors Shatter jimspeer 2006 Safari 0 11-06-2007 07:32 PM
Free Rose Mirror Insert for Cabinet Door Barkingspider Cabinets, Counter Tops & Furnishings 0 05-31-2006 10:36 AM
1966 Overlander ... Bathroom removal gitnmybelly Sinks, Showers & Toilets 17 02-12-2006 11:49 PM
Bathroom Mirror Joe62984 General Interior Topics 1 02-25-2004 08:38 PM
Bathroom Mirror niftypkg General Interior Topics 4 09-03-2002 06:38 PM
