Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-04-2006, 09:53 AM   #1
cameront120's Avatar
Profile:  1972 25' Tradewind
'72 wet bath tambour
The Tambour in the wet bath of my 72 Tradewind is jammed and will not open more than 6", so I can't even see what might be preventing it from rolling. It is also fit quite tightly in its tracks and won't lift out. Does anyone have any suggestions for removing it without destroying it? If I should have to cut it to get it out, has anyone come up with an alternate replacement? I'm thinking some sort of flexible plastic sheet rather than the wood tambour. Any ideas?
Cheers!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 04-04-2006, 10:13 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Cheers!
If it is the same as my 1971 was, then the only way to get it out, and to get it to work again is to loosen the bottom section of the bath vanity and gently bend it down. There might be crud in the tracks, or the entire vanity has shifted and is jamming the tambour shut.
Start at the wide side bottom,and start removing rivets and screws. You will also have to somhow managet o take alook inside the tiny closet next to the sink, if so equipped. Some of the securing screws come through the divider wall and into the extrusions.
The vertical extrusion on the left under the sink will have to be freed on teh bottom for this to come loose. You will have to re-caulk with silicone to make all the joints water proof again. I once removed my entire wet bath to replace a floor section that had rotten underneath the shower pan.
Uwe
www.area63productions.com
Old 04-04-2006, 10:23 AM   #3
Lee Pace's Avatar
Greenville , Texas
72 Wet Bath Tabour
Cameron,
We had the same problem with the tambour under our kitchen sink. My husband made a new door for it, using the tambour's as insets on the new doors. It looks so professional and is so much better. I will try and post a photo for you.
Good luck,
Lee Pace
72 Tradewind
WBCCI 7287
Greenville, Tx
Lee Pace is offline   Reply With Quote
Old 04-04-2006, 11:07 AM   #4
Thanks for the info Uwe. The setup you describe sounds identical to what I have. I'll do a little poking around after work to investigate. Do you happen to know what size rivets are used on the interior? I'll have to pick up some appropriately sized drill bits and new rivets on the way home.
Thanks Lee. A photo would be really nice to see if you get a chance!
Cheers!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-04-2006, 01:10 PM   #5
uwe
418
uwe's Avatar
Images: 41
Cheers!
The interior rivets are mostly 1/8in aluminum. You can use a 1/8in drill bit, but there are numbered bits that work a little better and do not make the holes too big. they are a small fraction smaller then 1/8in. Although, I have used 1/8in drills quite a bit, never had a problem. Buy extras, they tend to break off at the most inopportune time and place...
Home Depot sells white pop rivets in their tool crib.
Uwe
Old 04-04-2006, 01:18 PM   #6
Thanks uwe. I've seen the white rivets you mentioned and will pick some up. I found a supplier near my home for the numbered drill bits, so those aren't a problem.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-04-2006, 02:09 PM   #7
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I went through this over a year ago with my trailer. I spent many hours removing the tambour door, cleaning the track and the door, lubing it with wax, and reinstalling.
Outcome. Not much better, and not worth the effort!
You can read the thread about it here..
http://www.airforums.com/forum...-me-12513.html
Good luck!
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 04-04-2006, 03:02 PM   #8
Very useful thread Tim. Thank you for that. It confirms my suspicions that I might be better off ripping out the tambour and finding a different material to replace it.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-04-2006, 03:45 PM   #9
uwe
418
uwe's Avatar
Images: 41
You need to make sure that upon reassembly the tambour is not once again wedged vertically into the tracks, then it should work fine. I think the problem is that the palstic distorts over time and makes the top/bottom distance somehow too tight for the tambour to moove freely in it's track.
You will find a spiral ( the main culprit here) in the back under the sink, which also might need to be adjusted so it has extra clearance top to bottom. The transition from the track to the spiral needs to be very well aligned. I eventually got mine to work where it easily opened about 80% before it got really sticky.
the curved shape of the vanity makes replacement with other materials difficult.
Uwe
Old 04-04-2006, 03:55 PM   #10
Safari Tim's Avatar
Images: 35
All I could think of is a small version of a shower curtain. Since it's part of a wet bath, and that would look pretty tacky to me.
Best bet for me was just to get it so it opened and closed easily enough to get to the tp! ;-)
-Tim
Old 04-04-2006, 05:50 PM   #11
Profile:
wet bath tambour
After many hours, months and years of trying to fix the bath tambour in our 1971 23' Safari, I came to a very simply solution. I tore out everything in the bath sink area and threw it in the trash. Then I built a new counter top with a small round sink and covered the top with Formica. I moved the blower motor to inside the storage area to the left of the sink and lengthened the exhaust tube. I will try to upload a photo as soon as the batteries in our digital camera are charged. Life is so simple.
Dan
P.S.
Anybody need a yellow plastic bath tambour for free?
Dbraw is offline   Reply With Quote
Old 04-05-2006, 07:56 AM   #12
Profile:
Bath tambour
Attached are two photos of the new counter top and sink in our 1971 Safari.
Dan
ID:	20188   Click image for larger version
Old 04-05-2006, 09:49 AM   #13
Dan, thank you for your suggestion and photos. This may be something that I will consider doing with mine if I can't get the tambour working properly. I think part of the problem is that it is just too tight, so I'm going to try trimming it and re-installing. I'll also give the tracks a good cleaning. If all else fails I'll enlist the help of a millwork fabricator I know to come up with something nice...I'm thinking a Corian or Silastone counter and teak cabinet.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-27-2006, 07:04 AM   #14
Profile:  1976 25' Caravanner
Campton , New Hampshire
As Uwe has said , cleaning is the key . Also if something has sagged and there is no up and down movement the doors will jam. I have gotten all of mine back in working order . Once or twice a year I squart some silicone spray in the tracks and work them back and forth a few times. Check and see if there is any up and down slack in the doors , if not you will need to adjust something . If you do decide to take them out and replace with something else , please don't through them out until you offer them up , someone out there is trying to restore theirs and could really use them . Good luck which ever way you go.
ticki2 is offline   Reply With Quote
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 01:36 PM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 06:09 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
