Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-09-2004, 08:29 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Unhappy '71 Bathroom Tambor beat me!
This cabinet door has never worked since I got the trailer. I need to remove it and see what I can do to get it going but I cannot figure out how to remove it.
Has anyone done this without ripping the cabinet completely apart in a fit of anger?
Here are some pictures of the door I'm talking about.
ID:	7614   Click image for larger version
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-09-2004, 08:50 PM   #2
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
Send a message via AIM to Sneakinup
I took mine out on my 72 Overlander, and it was all I could do not to get a sledge hammer and smash it. It required pulling all the trim off above and below it. That means removing the brittle plastic inserts to expose the 300 rivets holding it in place. Oh, and there are some strategically placed sheet metal screws... at least there were on mine. Sorry to say, it is a nightmare!
Good luck!
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 07-09-2004, 10:02 PM   #3
Safari Tim's Avatar
Images: 35
I think you just convinced me I don't need it as bad as I thought:-)
After all your efforts, do you have a nice working door?
-Tim
Old 07-09-2004, 10:07 PM   #4
Master Riveter
Sneakinup's Avatar
Images: 72
The door worked fine, I removed it to modify the cabinet. I'm not putting it back in, but rather going to build a solid door that folds down. My area in the bathroom is a straight run rather than making the curve I see in your picture.
Old 07-09-2004, 10:20 PM   #5
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Tim,
I took mine out, due to having to remove the entire vanity panel/sink assembly.
Here's how:
Remove the lower yellowish trim insert and find the rivets that hold the vertical leftmost extrusion. remove the trim from this extrusion also. Reach around inside the little closet and find some of the sheetmetal screws that go in the approximate area of this extrusion.
The idea is to loosen, but without removing, the lower part of the cabinet.
Remove the rivets that hold the bent up part of the lower shelf to the rear inner skin. Start wiggling on things and see where else it's fastened. It is really not that bad. Look under the lower tambour snail with a mirror, it will show the remaining rivets or screws, depending on how they originally put it together. The lower left part of the cabinet can eventually be pushed down far enough to release the tambour from the groove holding it captive. You can wedge a piece of 1x2, cut to the right length, in there, to keep the space open. Most likely ther is a bunch of crud inside the tambour track, behind the covering, keeping it from sliding smoothly. Also, make sure the plastic snail track pieces line up perfectly with the aluminum track. If you keep tugging and removing rivets down below, you will not have to remove the sink, plumbing, or upper vanity parts. Just be patient, and gentle. Good Luck!!
Uwe
www.area63productions.com
Old 07-09-2004, 11:30 PM   #6
Safari Tim's Avatar
Images: 35
Thanks for the nice instructions Uwe.
Were you able to put it back together and did the door work smoothly?
-Tim
Old 07-09-2004, 11:57 PM   #7
uwe
418
uwe's Avatar
Images: 41
Ahm, no. I had the bathroom refinished, including the tambour. The paint coating is thick, too thick for the track, I found out.
It was sliding fine before, now it's very sticky, and only opens about 1/2.
So, I will be doing the same thing you're doing, AGAIN.
Uwe
Old 07-10-2004, 12:31 AM   #8
Safari Tim's Avatar
Images: 35
Like the saying goes, you do it right cause you do it twice
Lets have a race to see who gets it working smoothly first.
Ready?
Set?
GO!
-Tim
Old 07-10-2004, 10:01 PM   #9
Safari Tim's Avatar
Images: 35
OK, I did it...
I cut the small trim piece because the risk of totally ruining it since it was so brittle. This gave me access to drill out the rivets.
-Tim
Old 07-10-2004, 10:03 PM   #10
Safari Tim's Avatar
Images: 35
BTW, now I learned you only need to undo the bottom trim piece. And all the rivets on the bottom of the cabinet holding the lower track on. This way you can drop the lower track to get the door out.
I got the door out and the two track pieces. You can see how dirty the door bottom is from 30 years of scum.
-Tim
Old 07-10-2004, 10:06 PM   #11
Safari Tim's Avatar
Images: 35
Next, I cleaned the door and track pieces with simple green and got all the scum off. Then I lightly sanded it with 220 grit sand paper along the top and bottom edges to make is smooth.
Next I took a candle and ran the wax across the bottom and top cabinet door to give it something to glide on. Also put some wax in the track pieces.
-Tim
Old 07-10-2004, 10:10 PM   #12
Safari Tim's Avatar
Images: 35
Finally I cleaned the track in the trailer with the brush and got it spotless. I reasembled everything carefully and got it all back together.
And the final verdict is.... it was a good way to waste 4 hours. The door still only opens about a foot from the right. After it gets past that the door starts binding and folding on itself. I think it is just a terrible design.
So the only good thing about the experience is at least I tried and I don't have to wonder if I can get it working. I can't
My advice to someone who wants to attempt this is to just live with it or rip it out all together and put something different in!
-Tim
Old 07-11-2004, 12:29 AM   #13
uwe
418
uwe's Avatar
Images: 41
Shucks! My door worked well before I had it painted. After having it painted it is sticking, just like yours.
Ok, i won't mess with it any longer.
Uwe
Old 07-11-2004, 09:44 AM   #14
Profile:
Bathroom tambor
SafariTim,
I had the same problem with our '71 Safari bathroom tambor. After taking it out several times and working with it, I finally gave up and closed the door and don't plan to ever try to open it again. Just won't slide open and closed without a lot of cussin'. Really don't need the space anyway.
Dan
Dbraw is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Bathroom Restoration Before/After Pics PizzaChop Repairing/Replacing Floor &/or Frame 21 02-05-2005 06:34 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 08:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
Wanting to replace the WHOLE bathroom... larrylisa Sinks, Showers & Toilets 16 12-06-2002 01:08 AM
