Old 02-19-2012, 08:31 AM   #1
1977 23' Safari
Magnolia , Texas
Send a message via AIM to JillyBean63 Send a message via Yahoo to JillyBean63
'70s Plastic Cabinets
Can these be painted or do I need to replace them. My new, old 77 has plastic cabinets and upper bins and they are ugly! What about interior walls, can they be painted? I assume it's some sort of plastic as well? Complete newbie and trying to figure it all out. Thank you!
Jill
JillyBean63 is offline   Reply With Quote
Old 02-19-2012, 08:36 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What upper bins are you talking about/ AFAIK, the only "bins" are the old brown plastic bins that go in the lower storage areas under the beds and gaucho.
Oh, and those brown bins will crumble to dust if you give them a hard look.
Old 02-19-2012, 08:42 AM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I painted the interior walls and upper storage cabinets in my 82. It turned out great. Tape up well and take your time.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 02-19-2012, 09:44 AM   #4
Ottawa , ON
Assuming you have tambour doors in your upper lockers, did you paint that too?
If so, photos would be great...
Old 02-19-2012, 09:58 AM   #5
1977 23' Safari
Magnolia , Texas
Wow, C_Lewis, your walls and upper storage with the roll doors look great. It looks like you painted the upper storage as well? Are the slide up fronts on that storage called the tambour doors? Brand new!
Old 02-19-2012, 11:34 AM   #6
1974 Argosy 20
Kooskia , Idaho
Here are a couple of photos of my 74 Argosy tambour doors over the front, after painting with Krylon Fusion satin white paint. The upper end caps were also painted. The trim insert is countertop plastic laminate, cut into strips and butt jointed.
Name:	Tambour door paint 1.jpg
ID:	151468   Click image for larger version
Name:	Tambour door 2.jpg
Old 02-19-2012, 11:45 AM   #7
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I painted the overhead bins and the tambour roll up doors with krylon satin spray paint. The walls I painted with a brush and small smooth roller. I will post some pics soon
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 02-19-2012, 11:56 AM   #8
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Barry, a member in Florida who goes under the forum name Sneakinup, did an absolutely astonishing renovation of a 1970's trailer mostly using spray paint.
He has been an inspiration to many on this site.
- Photo Gallery
Sergei
Sent from my iPad
SmokelessJoe is offline   Reply With Quote
Old 02-19-2012, 05:15 PM   #9
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Here are the pics of the upper lockers with the tambour doors. I painted the lockers over the kitchen counter, dinette, and over the front couch. The spray paint is a must to get in all the nooks.
ID:	151511   Click image for larger version
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 02-19-2012, 07:43 PM   #10
Ottawa , ON
VERY nice work. I like it a lot.
Did you remove the tambour doors from the cabinets to paint them?
Old 02-19-2012, 08:46 PM   #11
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I actually painted them in place. It took longer to tape them up than to actually paint them. They were a yellowish color when I started. The repaint made a big difference.
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 02-19-2012, 10:21 PM   #12
1974 Argosy 20
Kooskia , Idaho
And I removed mine and painted the tambour outside, where I could see it easier. Then the end cap was painted, with everything removed from it, so masking was less of an issue. Still, when painting inside, wear a mask, do it on a nice warm and dry day, and use a big box fan exhaust the air and overspray paint dust.
Old 02-19-2012, 10:26 PM   #13
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
That is exactly right. Masks and ventilation is a must if painting inside....good call!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 02-20-2012, 06:56 AM   #14
Ottawa , ON
Thanks for all the great info!
'70s Plastic Cabinets JillyBean63 Cabinets, Counter Tops & Furnishings 18 03-23-2014 12:46 PM
Fresh water tank barbed plastic fittings Mrad7777 Fresh Water Systems 3 02-21-2012 12:47 PM
Looking to buy '68 or '70s Airstream in AZ silverwoman Airstream Lifestyle 13 02-15-2012 11:58 AM
Fiberglass or plastic? blumob Sinks, Showers & Toilets 3 02-09-2012 07:29 PM
Broken 70s Letters Zeppelinium Cleaning, Stripping & Polishing 15 02-09-2012 10:16 AM
