Old 09-10-2009, 09:39 PM   #29
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Gaucho extension
As promised, heres some pic's of my latest project.
Please be warned that it ain't pretty, I'm just trying out the geometry!
ID:	86992   Click image for larger version
ID:	86994   Click image for larger version
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 09-11-2009, 12:42 PM   #30
funkill's Avatar
reno , NV
Images: 27
how about a People Prop
Good design! It reminds me of a product that I've been a part of in development: the "Pooch Prop". After 6 years of paper/legal stuff we finally found a small shop to start producing it. It's essentially a board that is hinged and pulls from between your mattress/box-spring then a portion folds down 90 degrees to form the *legs*. This might be an idea for you folks .... ?????
I don't have any pics here but below is a quick sketch of the concept that we started with. The hinge area was modified a bit - but I think you can get the gist!
Laura
funkill is offline   Reply With Quote
Old 09-11-2009, 01:00 PM   #31
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
If anyone cares to take a closer look at the photos, you may be able to decifier the original design intent. The 3/4" legs were previously hinged to each side of the plywood. They were made to interlock and drop down for use.
They ended up not be rigid enough without some more bracing. I'm sure if I was patient enough, I could work it out.
DanB
www.campnova.com
Old 09-11-2009, 01:11 PM   #32
funkill's Avatar
reno , NV
Images: 27
Ahhhhhh. So THAT'S why it looked familiar! Our second (or third) prototype was made of paraply and gave the nicest finish. I guess ours was more rigid because the foot-print is quite a bit smaller than yours. We seem to have been on the same page - or at least in the same book!
Laura
Old 09-11-2009, 11:55 PM   #33
1971 27' Overlander
Boulder City , Nevada
what a lot of great ideas and pictures. Thanks. I really like the dinette conversion. I think I feel a winter project coming on
zigzag is offline   Reply With Quote
Old 09-12-2009, 02:55 PM   #34
STREAMTEAM's Avatar
1973 23' Safari
Tucson , Arizona
A few more picts of Molly's new dinette with some detail of the storage we gained and how they framed it in...we realy like the new bambo flooring, so far seems easy to take care of and is also very durable.
Mike
ID:	87082   Click image for larger version
ID:	87084   Click image for larger version
ID:	87086   Click image for larger version
STREAMTEAM is offline   Reply With Quote
Old 09-20-2009, 07:57 PM   #35
1971 27' Overlander
Doing the "after-trip" clean and fix. We took another look at why our gaucho was so hopeless. We discovered that the plywood on the back part was way out of place....had shifted downwardly, allowing the cushion to cave in under the shelf and the seat to shift forward. We unzipped the upholstry, slid the board up to better defiene the seat back. Better have two strong people working when you try to zip it back up. Once we had the back plywood in the right place, we discovered the back "sits" on the small, curved cushion that is behind the seat. That keeps everything in the right place. Amazing!! Now, it seems to be a comfortable couch. I did get a memory foam topper for the next time we use it as a bed. Still like that dinette do, tho. May still be a winter project.
Old 09-20-2009, 08:32 PM   #36
Kevin245's Avatar
Mike
Streamteam,
Very nice work on the dinette.
Eleanor Roosevelt
Old 09-21-2009, 08:52 AM   #37
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
While we had our gauchos out so I could reupholster, I made a long pillowslip type fabric cover for that back board, so that it could slide in, and put it inside the new cover. I left the fabric just enough hem on the top of the board to use the sewing machine to "tack" it to the back piece of upholstery. That keeps the board from rubbing through the upholstery fabric and the "tack" keeps the board from sliding up, down or sideways. It seems to be working great.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 09-21-2009, 09:07 AM   #38
Ottawa , ON
it's called a "Front Travel Lounge Assembly" by AS
And here is a diagram of it with descriptions from the 1974 Service Manual:
Old 09-22-2009, 11:38 PM   #39
1971 27' Overlander
loudruff, what an easy solution. Lots of great info and suggestions. Much thanks...
Old 10-29-2009, 11:29 PM   #40
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Dinette Replacement
Hey Streamteam, what did that awesome dinette conversion cost? Looks like the way to go.
RichHog is offline   Reply With Quote
'70s 12V electrical question Zeppelinium Lights - Interior & Exterior 3 06-17-2009 10:34 PM
replace gaucho danuzie 1987 - 1989 Excella 1 06-30-2007 11:31 PM
Does Anyone Have?????? Goucho Arms AirstreamGypsy Upholstery, Blinds, Walls & Interior Finishes 16 11-14-2006 11:59 AM
Looking for a Goucho ptbasmith Cabinets, Counter Tops & Furnishings 3 05-12-2006 12:11 PM
Question for owners of mid twin bed units of early 70s mello mike Cabinets, Counter Tops & Furnishings 16 01-09-2006 07:55 AM
