Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 01-25-2009, 12:26 PM   #1
aircooled4's Avatar
Profile:  1971 31' Sovereign
1967 22' Safari
Pardeeville , Wisconsin
'67 Safari table hinge...
Here is a pic of the joint between the 2 table halves...Im guessing that the 3 small hinges dont belong here...how was it done originally? I was also looking at how the table leg assembly pulles out to allow the table to be opened up...The leg thats on there is hte kind that can be flipped back underneath...Just from looking, that shouldnt be done or the weight of the table will pull it from the wall...SO...what leg shoud be on it? and how is this thing hinged?
Jay (KB8VMO) & Sheri
Kids, cats, horses, & donkeys
WBCCI #10917
AIR #32349
aircooled4 is offline   Reply With Quote
Old 01-25-2009, 02:42 PM   #2
Shacksman's Avatar
Profile:  1967 22' Safari
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
My 67 Safari has the original table. The joint has a full length piano hinge. There is another joint about 4" from the wall with another hinge that lets the table fold up into the window, the leg folds down like you say. I can even close the curtains over the table and it disappears. This allows the twin beds to pull out from the wall with about a foot between them.
Let me know if you need a picture, we are using the trailer right now so could get a pict. easily.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 01-25-2009, 02:54 PM   #3
aircooled4's Avatar
1967 22' Safari
Thanks! that explains the leg and the hinge...A pic would be great...that way i can see how it SHOULD attach to the wall! Thanks!
WBCCI #10917
AIR #32349
Old 01-25-2009, 04:29 PM   #4
aircooled4's Avatar
1967 22' Safari
Heres a pic of how the table was mounted...you can see that the table top slides into the this part thats mounted to the wall...making it immovable...I can see where a hinge MIGHT be able to be placed...there are no covered holes from where a hinge might have been...the collapsable leg looks to not be original, appears that a fixedleg was there...
WBCCI #10917
AIR #32349
Old 01-25-2009, 05:37 PM   #5
silverleeper's Avatar
1960 18' "Footer"
Edmonds , Washington
Table
Hi, I replaced the old leg with a stock one from a hardware store. It is mounted solid. The second photo shows the table to the wall. The third shows the slide being extended and the table would flip over and rest on the extension. The four photo shows the table in its most compact position.
ID:	74574   Click image for larger version
ID:	74577   Click image for larger version
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-25-2009, 06:51 PM   #6
aircooled4's Avatar
1967 22' Safari
Lee,
Does yours fold up completely infront of the window? Your leg looks like the round one that was probably on mine...i can see where it had been replaced with the collapseable one...
WBCCI #10917
AIR #32349
Old 01-25-2009, 09:20 PM   #7
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Here's some pictures showing how mine works. It can be folded up into the window and down as one short table then opened over to twice the length. The foot is attached to a slider that pulls out to support the fold over. The short piece is attached to the wall with 2 small shelf brackets that I don't think would be original but work quite well. I have the original table but this is a replaced top I made that fits our use better.
ID:	74592   Click image for larger version
ID:	74594   Click image for larger version
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 01-25-2009, 09:24 PM   #8
BIGED52's Avatar
MILAN , Illinois
My table is mounted the same way (permanent) bracket (non-folding) to the front wall under the window. The leg is a simple one (non-folding) mounted to the center of the sliding frame (original) that expands the table for the extension top to be folded out over the frame. However, the hinge between the two tabletop halves originally had a plastic hinge that was molded and fit between the two halves when folded out to its longest length. This folded hinge then provided for a nearly invisible seam between the two tops. My hinge part has long ago failed at the fold between the tops but is still attached to the edges of the tabletop sections. None of it was supposed to fold except for the plastic hinge on the tabletop itself. It is always in the way when sleeping on the twins and I guess that when it was opened to let more than two use the dinette that that is the reason the tops hinge finally failed. The piano hinge is the only way I know of that the original function of the two tops can be restored but it leaves the spine/pin of the hinge above the table top when open to the full length. I have not yet decided how to deal with this problem in my own dinette so if you come up with a good fix that takes the place of a piano hinge please let me know. Hope this explains what you asked about. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-25-2009, 10:04 PM   #9
1960 18' "Footer"
Originally Posted by aircooled4 View Post
Lee,
No, It does not fold up toward the window. If you look at the last pic thats as small as the stock table gets. It looks like Doug has made a different setup that will do that for you if thats what you need. I've not had a problem with the twin beds with the table fixed position. It's nice to see a different option though.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
'67 Safari front table info needed. mackellar General Interior Topics 3 08-19-2009 06:14 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 11:27 AM
68 Safari Table hardware & seat/bed info niss1679 Cabinets, Counter Tops & Furnishings 28 09-01-2005 07:39 PM
Replacement Fold Out Table for 74 Safari chellmann Cabinets, Counter Tops & Furnishings 10 12-19-2004 12:16 PM
Looking for 1974 23' Safari Fold Out Table chellmann Parts Archive 1 08-03-2004 07:54 PM
