Old 02-05-2019, 08:19 PM   #15
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks folks for the excellent advice. I think I better stick with a good quality piece of 3/4" ply for the counter top. I will have a drop in cooktop but no oven, and my trailer is a double sink. The new kitchen faucet is fairly light weight, but I will use a doubler under it for some extra support. The aluminum edge moldings are designed for 3/4" material so 1/2" would cause some odd looking miss match.
I've read about baltic birch plywood, but I've never worked with it. I'm using a good quality wood laminate over MDF for my 1/4" needs. It is a strong material, heavier than ply. I was cautioned to seal it well with poly as it can warp if wet.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 02-06-2019, 02:10 AM   #16
Long Island , New York
Sounds like a good plan, thanks for the update.
Peter
Old 02-06-2019, 02:22 AM   #17
2002 19' Bambi
Lafayette , California
Although you have already chosen your solution, there is a way to avoid eventual warping. That happens to be gluing laminate to both top and bottom of the plywood. It doesn't have to be the same pattern of laminate.
I am also a proponent of Baltic birch. I have used it for all of the numerous changes in our Airstream.
Tim
Tim A. is offline   Reply With Quote
Old 02-06-2019, 08:52 AM   #18
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Originally Posted by BambiTex View Post
Of the sink:-)
Here you go!
Personally, I'd stay away from MDF. It turns back into sawdust when it gets wet, it's heavy, and produces toxic sawdust.
Name:	2017-08-15 15.15.30.jpg
SuzyHomemakr is offline   Reply With Quote
Old 02-07-2019, 06:23 PM   #19
2018 25' Flying Cloud
AURORA , Colorado
ROBERTSUNRUS - I LOVE what you've done here with your living room remodel. We've been discussing options for replacing the table in our 25'Flying Cloud RB and this looks like the best of both worlds - counter space for "must have's" but the table is out of the way when you don't need it.
MattsGal is offline   Reply With Quote
Old 02-07-2019, 06:34 PM   #20
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
I would stay away from MDF board due to moisture, it will swell up around sink just from humidity and during storage.
Steve
heslinhotel is offline   Reply With Quote
Old 02-10-2019, 05:54 PM   #21
Dick tracy's Avatar
camas , Washington
plywood for counter tops
3/4" plywood is the standard in cabinetry, we double it up to 1 1/2" for most applications. AS of course use 3/4". ALWAYS use plywood at wet areas, MDF although smooth will not stand up to any moisture and will swell.
3/4" has structure that 1/2" does not as it is too flexible and even your screws will create visible dimples. the cost difference is negligible.
Dick tracy is offline   Reply With Quote
Old 02-10-2019, 09:15 PM   #22
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good advice. 3/4" it will be. I am considering Corian also.
David
WBCCI #8607
VAC Region 11
Old 02-10-2019, 11:48 PM   #23
Dick tracy's Avatar
camas , Washington
Yes, Corian is best, super strong and durable, easy to clean and you can get integral sinks. I will definitely be switching to all Corian tops in my 2017 23fb.
Flying Cloud counter tops - formica Star Ship 2016 - Current Flying Cloud 28 10-24-2018 06:12 PM
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 07:29 AM
Replacing formica counter with corian To Gulls Cabinets, Counter Tops & Furnishings 12 11-18-2014 12:23 AM
Any pics out there of painted "fake wood" or covered it with formica? nurse222 Upholstery, Blinds, Walls & Interior Finishes 16 07-22-2010 06:57 AM
