Old 01-25-2019, 07:48 PM   #1
Calgary , California
Replacing WFCO 9855 Converter on 2018 Classic30
We just picked up a pair of Battle Born 100ah LiFePO4 batteries at the Quartzsite RV show to replace the failing factory-installed Interstate SRM27 batteries. Next is replacing the WFCO 9855 converter with a unit suitable for fully charging lithium batteries. Our converter appears to be located on top of the wheel well under the closet floor with no easy access. It seems that the only way to access the converter is by removing the stove/oven since the closet floor does not seem to be removeable. Has anyone done this? If so, what converter did you use? WFCO advises that the 9855 profile is not suitable to fully charge Li batteries, and we should use their WF9850L2 as a more suitable upgrade. I would appreciate advice on accessing the converter and on best choice for replacement. thanks
rdsyl is offline   Reply With Quote
Old 01-26-2019, 05:52 AM   #2
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Call Randy at Best Converter. He's also a fellow Airstreamer.
glcmranger is offline   Reply With Quote
Old 01-26-2019, 06:08 AM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I can't offer any suggestions but am interested in the outcome. So I'm just tagging along.
« 1980 24ft Caravelle | Top | - »
2017 converter vs. 2018 converter. Mollysdad Batteries, Univolts, Converters & Inverters 14 06-01-2018 06:11 PM
WF-9855 never goes to 13.2V Roguegaston 2016 - Current Flying Cloud 33 04-19-2018 06:01 PM
WFCO Ultra III 30 AMP Power Center w/ Converter Charger Danossola Airstream Classifieds 0 07-17-2016 04:08 PM
GypsyCowgirl - Classic30 :: 2016 Airstream Classic gypsycowgirl Airstream Registry Discussions 0 03-24-2016 03:46 PM
wfco 9800? rama777 Electrical - Systems, Generators, Batteries & Solar 6 10-02-2006 10:14 PM
