Old 07-20-2013, 09:20 PM   #1
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Got it home
Well we got it home or first AS. 1980 24ft Caravelle.
Now the fun part starts. Outside is in really good shape just some black marks on it from a tarp rubbing on it. Any ideas to get them off would be welcome. Inside will take some work. Just want to get every thing working to start with. Also get a service manual since Airstream says that the owner's manual for this model are not available.
Name:	trailers pictures 209.jpg
ID:	191316   Click image for larger version
Name:	trailers pictures 211.jpg
Name:	trailers pictures 210.jpg
thehandyman is offline   Reply With Quote
Old 07-20-2013, 11:55 PM   #2
2005 19' Safari
GLENDALE , AZ
I would first try washing the black marks gently with auto shampoo, water and a soft sponge or rag, as if you're just washing your Airstream. Don't rub too hard; you don't want to damage the underlying finish on the aluminum.
If the black marks don't come off by just washing the panels, I'd try a little auto wax (like Turtle Wax or whatever you have handy) in a small area, to see if the solvents in the wax will loosen up the black stuff. It might just dissolve and rub off. If that works, just wax the areas where the black residue is.
Next, you might try an art gum eraser. These are made of soft gum with absolutely no abrasives that will cause scratches. Again, tray a small area first.
Do not use anything abrasive, like Bon Ami or Bar Keeper's Friend, because this will damage the finish and scratch the aluminum. Basically, don't put anything on the aluminum panels that you wouldn't put on the painted finish on a new car.
If none of the above works, you might try a commercial "goo" remover, like Goo Gone or a similar product. Just try a small area to see what happens before smearing it all over the side of your Airstream. Be careful, as some products contain strong solvents that will dissolve clear coat and whatever other finish may be applied to the aluminum panels.
Good luck!
Old 04-11-2014, 07:58 AM   #3
1969 18' Caravel
Fort Worth , Texas
Handyman, what brand of aluminum polish did you end up going with? I tried brasso with no luck and also zep.
SarahCaravel is offline   Reply With Quote
Old 04-13-2014, 05:39 PM   #4
1980 24' Caravelle
I used Mothers Mag and aluminum polish. I did not try and remove the marks completely but they are not as noticeable now.
Old 04-13-2014, 06:20 PM   #5
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
You might contact the Wally Byam club about your manuals. They seem to have some in their files and will make a copy for you for small fee.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
