Old 07-22-2014, 11:04 PM   #351
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I ordered a Newport Dickinson P9000 propane fireplace a month ago and it finally arrived today. It is really well built like most marine systems.
I installed it today.
The worst part was getting the courage to drill a 3" hole in the roof
Name:	ImageUploadedByAirstream Forums1406091070.222732.jpg
Name:	ImageUploadedByAirstream Forums1406091099.109586.jpg
I mounted it above the kitchen counter. It only takes a 12v power source and the gas line. The flue has an inner exhaust pipe and an outer fresh air intake. It is quite flexible and is able to make the bend to the roof quite well and mount on the wall it comes with a backing plate which provides an offset to minimize the heat transfer to the wall.
The vent attaches to the roof with 6 stainless screws and a thick rubber gasket. I added a bit of Vulkem for good measure.
Name:	ImageUploadedByAirstream Forums1406091345.244912.jpg
The inner pipe and outer pipe are both screwed into the vent fitting and then the whole assembly is slid through from the top. Then the interior trim is installed with 4 stainless screws.
Name:	ImageUploadedByAirstream Forums1406091442.664060.jpg
I drilled a hole in the standoff piece for the power wire and then attached the standoff piece to the back of the fireplace. The whole thing was put into place and connected to the the flue stack. It is screwed to the wall with 4 10x 3/4" SS screws.
Name:	ImageUploadedByAirstream Forums1406091818.340051.jpg
Name:	ImageUploadedByAirstream Forums1406091838.808415.jpg
Name:	ImageUploadedByAirstream Forums1406091863.774367.jpg
timzog is offline   Reply With Quote
Old 07-22-2014, 11:24 PM   #352
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
A few thoughts about the fireplace.
Why I like it:
-totally solid construction and really simple.
-visible fire ambiance
- low power draw for fan 0.2 amps on high setting
- able to run without any power if necessary
-super quiet fan even on high
-2 settings for propane consumption
-direct vented so does not draw air from the interior for combustion or exhaust in the trailer.
Some concerns
-no thermostat. It is either on or off. Once it is off, you have to relight it manually to turn it back on.
- the place I ended up mounting it is not ideal. It would be better to mount it closer to the floor, but that just doesn't work with my floorplan. The heat is exhausted out the bottom so it may result in hot heads and cold feet since it will blow onto the counter. I am going to leave space for a duct in the kitchen cabinet in case I need to add a fan to blow the air from the bottom of the heater to the floor.
Old 07-24-2014, 08:09 PM   #353
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Filled the water tanks today and tested the water pump. It was a bit louder than I had hoped, but it works! Here is the requisite running water pic!
Name:	ImageUploadedByAirstream Forums1406254182.697966.jpg
Old 08-09-2014, 08:43 PM   #354
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Finished all the LPG connections today and tested the water heater, stovetop, and fireplace. All worked beautifully.
Name:	ImageUploadedByAirstream Forums1407638457.865475.jpg
Name:	ImageUploadedByAirstream Forums1407638486.431782.jpg
Also, tidied up some of the fresh water connections.
The big lines are the fresh water fill and the small lines are the vents.
Name:	ImageUploadedByAirstream Forums1407638591.767048.jpg
Name:	ImageUploadedByAirstream Forums1407638616.681828.jpg
Old 08-16-2014, 10:38 PM   #355
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
One step backward, two steps forward.
So my fantastic fans have been leaking. Brand new installs 1 and 2 years old respectively. I went on the roof to check it out and the plastic flanges have cracked at the screws. I think there are two problems. I used rivets to attach them and the attachment of a flat piece of plastic to a curved piece of aluminum. Fantastic fan immediately sent me two new fan bases at no charge, no questions asked. Excellent customer service!
I stole Aerowood's idea but not his tools or expertise and tried to do a better install of a fan. The back was a significant challenge since it is very curved at that position. Approximately 1/2" from flat in 16" in both directions. I had tried originally to use 1" angle underneath the skin to flatten the aluminum skin so that it would mate with the plastic flange. This may have worked if Imused different rivets, but I decided to try this new approach.
I bent some .032 stock into 90 deg angle about 1 1/2" x 1". I used my metal stretcher to match the curve in the outer skin. This is whatnot looks like when you are gentle
Name:	ImageUploadedByAirstream Forums1408249542.550120.jpg
This is what it looks like when you try too hard.
Name:	ImageUploadedByAirstream Forums1408249612.213856.jpg
These were clecod into place and then the top edge was cut into a straight line. These were buck riveted to the outer skin creating a lip all around the hole for the fan. This should stop any water from the skin getting under the fan. I should have got some help bucking rivets since one of them is sub par.
Name:	ImageUploadedByAirstream Forums1408249775.254285.jpg
Then I buck riveted 4 pieces of 1/16" angle to each one of these pieces to make a flat horizontal flange. Sorry not to take any pictures of this. I had too much Vulkem on my hands.
Then I used the the fantastic fan supplied gasket to attach the fan. I had already transferred all the parts and electrical to the new base.
Name:	ImageUploadedByAirstream Forums1408249860.003281.jpg
A couple of things I like... Buck riveted flange is the primary weather seal on the roof. Any water that lands on the skin will never see the fan seal.
The fan seal will be easy to change should there be a problem in the future.
The main problem is this took a lot of work and a lot of fussing to get all the parts together.it was easy to buck rivet the flange to the roof, but tough to buck rivet the top piece of angle to the flange. Here's hoping for a big rain storm to see if it works. By the way, I think this turned out OK, but if you want to see it done right, go to Aerowwod's thread.
Old 08-16-2014, 11:02 PM   #356
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Front fantastic fan replacement.
The front fantastic fan was easier to replace since the roof is much flatter at this location. Again, I think the problem was the use of rivets to attach the plastic flange to the metal roof. I used Vulkem to make the seal and the system failed In that the plastic flange cracked in several locations.
I first reinforced the interior and out skins by inserting some 2" u channel into the gap in the square hole. This was attached to the inner skin by pop rivets. I then cut two square pieces of 1/8" aluminum plate 16 1/2" square with a 14 1/4" square hole in the middle. This was used to create a 1/4" lip that would exclude most of the water that could get under the fan flange.
The aluminum flanges were buck riveted to the outer skin and u channel with 1/8" flush rivets in countersunk holes. A bead of Vulkem was applied between each layer prior to riveting. Here is the finished flange as I was drilling holes for the fan install.
Name:	ImageUploadedByAirstream Forums1408251490.580572.jpg
Then I drilled 5/32" holes aligned with the holes in the plastic flange. I put a gob of Vulkem in each hole, put the fantastic fan gasket in position and installed the fan with #10 x 3/4" SS screws.
I put a gob of Vulkem on each screw top and hooked up the electrical. I took the opportunity to clean everything in the fan when I put it together on the new base.
Name:	ImageUploadedByAirstream Forums1408251700.598217.jpg
Name:	ImageUploadedByAirstream Forums1408251731.270848.jpg
Old 08-26-2014, 07:36 PM   #357
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Creating a shower pan. Needed a transition between the vinyl floor and the aluminum floor of the shower. Used a 1/8" x1/2" Al bar which is the same thickness as the vinyl floor and a 1/4" x 1" bar which served as the threshold. Sanded the corners with 110,220 and 500 grit paper to make a nice soft edge for bare feet. Here are the pieces ready for install.
Name:	ImageUploadedByAirstream Forums1409103112.842843.jpg
Installed with two thin beads of Vulkem and 1/8 x1/2" pop rivets.
Name:	ImageUploadedByAirstream Forums1409103336.273375.jpg
Name:	ImageUploadedByAirstream Forums1409103371.343877.jpg
Old 08-26-2014, 07:48 PM   #358
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Now working on the door to the bathroom. Since a square door would too easy, decided to make it with a more nautical looking round top. The opening is 28" wide x about 76" tall.
I made a full template of the opening with hardboard. I stretched 2 pieces of 1/8"x 1/2" Al angle into semicircles with a 14" radius.
Name:	ImageUploadedByAirstream Forums1409103663.687060.jpg
I had to sand them extensively with a random orbit sander and 110 grit paper to remove most of the marks from the stretching. Here is a before and after sanding. Still not perfect, but I am afraid to sand it down to nothing.
Name:	ImageUploadedByAirstream Forums1409103824.460625.jpg
I cut aluminum sheet to fit front and back from the arch to the ceiling and pop riveted the whole thing together.
Name:	ImageUploadedByAirstream Forums1409103924.789113.jpg
Name:	ImageUploadedByAirstream Forums1409103944.078813.jpg
Now that the frame is done, I am working on the door. It will be a sandwich of .032" 5052 sheet, 1/2" blue foam, and Luan plywood, with aluminum channel frame all held together with rivets and epoxy.
I hope it works.
Here is the full template.
Name:	ImageUploadedByAirstream Forums1409104095.434395.jpg
Old 08-26-2014, 08:47 PM   #359
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Tim, looks like you have two good helpers there! Keep up the good work!
youngpeck is offline   Reply With Quote
Old 08-27-2014, 08:50 PM   #360
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Helpers
Yep! It is most fun when I get help. Help is always available when using clecos!!
Old 09-07-2014, 08:31 PM   #361
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Made some more progress on the bath door. It is tougher now to find time now that school has started again.
Here is the door hinge. It is a 6' x1 1\2" aluminum piano hinge from Zoro tools.
Name:	ImageUploadedByAirstream Forums1410142810.963477.jpg
I buck riveted the hinge to a .032" aluminum sheet that was 3/8" bigger than the door opening. This is going to be a shower door too so it needs to be waterproof.
I bent some angle for the top of the door and used U channel for 3/4" plywood for the sides and bottom. I sanded it all with 110 and 220 grit paper. The core will be foam, but there will be a6" wide bit of 1/2" plywood near the top as an attachment point for hooks.
Name:	ImageUploadedByAirstream Forums1410143102.865138.jpg
Here is the test fit of the frame, hinge and aluminum panel. It fits great.
Name:	ImageUploadedByAirstream Forums1410143314.661372.jpg
Next will be the wood skin for the side that faces the interior of the trailer. I was going to use luan but switched to 1/4" maple plywood with several coats of spar polyurethane. Except for the strip of 1/2" ply, the bulk of the core will be 1/2" blue foam. It will all be epoxied together in a sandwich and should be light and strong.
Old 09-07-2014, 08:35 PM   #362
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I am looking for ideas for a latch system that can hold the door in a closed position and also secure the door in an open position. I'd like to be able to travel with the bath door open so I can see out the back. I believe simple is better if possible. Any suggestions?
Old 09-20-2014, 10:45 PM   #363
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Making slow progress on bathroom door. Here is the inner material. The plywood part is reinforcement to support hooks.
Name:	ImageUploadedByAirstream Forums1411274512.351053.jpg
This is the door with unfinished plywood face.
Name:	ImageUploadedByAirstream Forums1411274646.221790.jpg
Here is the door in one final test fit before finishing and assembly.
Name:	ImageUploadedByAirstream Forums1411274694.479077.jpg
ID:	222429Click image for larger version
Name:	ImageUploadedByAirstream Forums1411274717.585906.jpg
Old 09-20-2014, 11:01 PM   #364
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Here's some work I did last week and forget to mention.
Added a voltmeter with a switch as well as a switch for the water pump.
Name:	ImageUploadedByAirstream Forums1411275670.703597.jpg
Name:	ImageUploadedByAirstream Forums1411275155.174858.jpg
1980 caravelle, 20', caravelle
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 10:44 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
old flange flush with new subfloor? valontjej Waste Systems, Tanks & Totes 10 03-13-2012 11:52 AM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 09:21 AM
