Old 06-29-2014, 10:16 PM   #337
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
AXLE!!
I ordered a new axle a month or so ago. It arrived within less than a week.
Name:	ImageUploadedByAirstream Forums1404097226.073399.jpg
I was under the impression that it was to be a drop in installation but it arrived disassembled which means that the brakes and bearings were in a separate box and would need to be packed and assembled by me. Not insurmountable, but an additional bit of work to do. Perhaps this is because I ordered the 12" brakes, but it was annoying. When I asked for the instructions on how to assemble the axle, I was told that if I didn't know how to pack the bearing and mount the brakes, I should get someone knowledgable to do it for me. Not exactly the level of detail I was hoping for, but I can figure it out. I went online and found a bunch of info so I think I can do it. Before I started work, I decided to measure the axle to check the dimensions. It turned out that it was the wrong axle. After a few phone calls, the suppliers were able to arrange for a new axle to be shipped and the other one sent back free of charge. Within another week, I had my 3500 pound torsion axle and the dimensions were correct. Yeah!!
I jacked up the airstream, built some block towers and screwed them and positioned them under he main frame rail on each side.
Name:	ImageUploadedByAirstream Forums1404097693.636553.jpg
For extra safety, I put some tires under the back and a few jack stands in random places and then said goodbye to the old wheels forever, except one that I'll keep for a spare.
Name:	ImageUploadedByAirstream Forums1404097845.509630.jpg
Here's a look,at the old axle.
Name:	ImageUploadedByAirstream Forums1404098028.743186.jpg
A few weeks ago, I started spraying PB blaster on the main bolts. Three came off with my biggest crescent wrench but the 4th one took the help of my neighbors impact driver. I lowered it down with a floor jack without dropping it on my foot and here it is.
Name:	ImageUploadedByAirstream Forums1404098102.869526.jpg
Here is the newly exposed mounting plate.
Name:	ImageUploadedByAirstream Forums1404098186.420430.jpg
timzog is offline   Reply With Quote
Old 06-29-2014, 10:47 PM   #338
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
1980 Caravelle Shell Off Renovation
Axle part II.
Before I installed the axle, I filed in a few trim pieces with .032. I didn't like how the frame was so exposed in the wheel well so, I covered the edges with sheet aluminum and sealed any cracks with Vulkem. My wheel wells are 1/8" Al plate so I sanded the surfaces with 60 grit using my random orbit sander and then brushed on truck bed liner I bought at Lowes. I also did the same to the inside of my aluminum battery box. I tried to take a picture, but you can't see the black surfaces at all. I hope it is very durable.
Back to the axle, I did some measurements to figure out what I needed to do to the mounting plate. My supplier told me to use the rear holes for positioning. In order to fit the larger main tube, I used my angle grinder and a cutoff wheel to trim about 3/16" from each side and then used the abrasive grinding wheel to round the corner. Not a perfect job, but it should work. I then painted all the exposed metal. Of course, I was dirty during all of this, so. I don't have a good picture.
I was able to raise the axle into position bit by bit with stacked boards and some levers. When I got close, I was able to put in the back bolt on both sides and then used my floor jack to raise up the front until it was snug with the belly pan. I had to drill out the front hole using a 5/8" drill which cost $17!!! I only had to expand the hole a little, and I think I could have done it with my 1/2" bit that didn't cost $17. I painted the freshly exposed surfaces and put in the final bolts.
I forgot to take a picture because I got distracted by trying to put on the shocks. Another surprise... The shock mounting bolts are not aligned. On the front one (on the trailer), the shock will ride on the part between 1 and 2" from the main frame.
Name:	ImageUploadedByAirstream Forums1404099383.993921.jpg
However, on the back one(on the axle), the shock would ride between 2 1/2 and 3 1/2" from the main frame.
Name:	ImageUploadedByAirstream Forums1404099499.797211.jpg
I am no expert on shocks, but I think that they need to be parallel with the frame. I contacted my supplier and I hope they can help me.
I may go ahead and start assembling the wheel assembly since I can install the shocks later and if needed, I can easily drop the assembled axle. I wonder if I can get my supplier to pay for the welding??
Anyway, I wanted to have some progress so I rolled the wheels into position and took some pictures just for fun. If only, it was that easy to get rolling.
Name:	ImageUploadedByAirstream Forums1404100013.352078.jpg
Name:	ImageUploadedByAirstream Forums1404100070.552884.jpg
Name:	ImageUploadedByAirstream Forums1404098618.765184.jpg
Old 06-30-2014, 09:42 PM   #339
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I made some more progress on the axle. I used a cutoff wheel on the angle grinder to cut off the shock mount (left side of following pic)
Name:	ImageUploadedByAirstream Forums1404182276.211508.jpg
I polished the area flat, drilled a 1/2" hole and hen used a 4" bolt with various nuts and washers and a 9/16" x 1/2" bushing to create a 3" shock mount.
Name:	ImageUploadedByAirstream Forums1404182470.882565.jpg
Name:	ImageUploadedByAirstream Forums1404182498.589933.jpg
I am much happier with the alignment now.
Old 06-30-2014, 10:07 PM   #340
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Brake and bearing assembly:
I didn't see much about how to do this on airforums, so I thought I'd show how I did it. This is my first time, so any feedback is welcome.
First mounted the brake to the the axle with lock washers and nuts. It is important to keep grease off the brake pads and to keep everything clean. I used lots of paper towels and compressed air.
Name:	ImageUploadedByAirstream Forums1404182634.310748.jpg
I then put grease on the back bearing ( the bigger one). To do,this, you put a glob of grease on your hand and force it by pushing he bearing into your hand. When grease comes out the top, you rotate the bearing a bit and do it again until the whole bearing is full. Then repeat to the other side of the bearing to be sure it is full.
Name:	ImageUploadedByAirstream Forums1404182727.648761.jpg
I smeared some grease on the bearing seat on the inside of he brake drum. With grease all over the bearing, you put the bearing in place. Below is the installed back bearing and the grease seal nest to it before it is installed.
Name:	ImageUploadedByAirstream Forums1404182866.713854.jpg
The inner slot on the grease seal is also filed with grease and the grease seal is placed over the back bearing.
Name:	ImageUploadedByAirstream Forums1404183002.190523.jpg
To protect the seal, I used a board and a rubber mallet to drive it flush with the face of the drum.
Name:	ImageUploadedByAirstream Forums1404183199.964032.jpg
Name:	ImageUploadedByAirstream Forums1404183176.425539.jpg
Some grease is smeared on the axle and then the drum is placed on the brake assembly carefully.
Name:	ImageUploadedByAirstream Forums1404183304.408486.jpg
Name:	ImageUploadedByAirstream Forums1404183321.315993.jpg
Then the smaller front bearing is packed with grease and installed in the outer opening of the drum.
Name:	ImageUploadedByAirstream Forums1404183409.254313.jpg
Then the washer is placed over the axle and the final nut is screwed in. I don't have a pic of the installed nut (my photographer is 7 and she lost interest and my hands were covered in grease&#128516 but the nut and cotter pin are shown in this previous pic.
Name:	ImageUploadedByAirstream Forums1404183546.867794.jpg
I tightened the nut with an adjustable wrench and then backed it off and tightened it by hand until there was no play in the drum. I then installed the cotter pin and bent it over in front of the hub just as it was in the previous pic. I then installed the grease cap. This really did not take very long and was not that difficult, but I had to hunt around to find the process. If I made any mistakes, please tell me!
There is still a bit of a scraping sound which I think is the self adjusting brakes, but I am not certain. When I finally start towing, I'll check the temp often to make sure everything's OK. I welcome any suggestions or improvements to this process as I will plan to retune my bearings every year. I think I could do both wheels in an hour now that I understand the process.
Old 06-30-2014, 10:21 PM   #341
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Had a great visit today by some new friends in SLC who go by Youngpeck on the forums. They wanted to check out my project as they are starting a renovation of their own. Not only did we have a great conversation, they brought me the coolest beer ever- Uinta Detour double IPA with an Airstream on the label. My wife immediately claimed the 4 pack holder for a condiment transport device.
http://www.uintabrewing.com/brews.php
Anyway, I am excited to watch their progress.
Old 07-14-2014, 11:09 AM   #342
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
LPG installation details
Working on correct sizing for my LPG lines. My Atwood water heater has a capacity of 8800 BTU and has a 3/8" inlet.
I found the following reference for LPG copper line sizing...
http://www.lp-gasequipment.com/produ...0_p157-175.pdf
With 3/8" line, and a 11" WC regulator, even with a 60' line, I would have capacity to run a 19,000 btu appliance with only a 1/2" pressure drop. With a 10' line, the capacity is 49,000 btu. This does not include bends, but I feel comfortable running a 3/8" line for the 10' back to the main branch. I will run 1/2" from the main regulator back to tees which will feed the SMEV gas stovetop, the newport Dickinson propane fireplace and the water heater. 3/8" will be plenty for all of these branches.
Going to half inch line doubles all the capacities roughly. The main half inch line will be less than 10' and would have a capacity of 110,000 btu, which seems like overkill, but should avoid pressure drops when running multiple appliances at once.
Old 07-14-2014, 10:08 PM   #343
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Took my old axle to a metal recycler today. I made $20.10. I told my wife that the Airstream project is now making money. She didn't laugh.
Old 07-17-2014, 03:13 PM   #344
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Just realized something I should have checked before shopping for copper tubing. In LPG, they use the OD of the tubing instead of the ID like they do for water lines. Took an extra trip to the hardware store.
I did some practice double flares on 3/8" tubing. It is important to keep everything lined up to get an even flare.
Here is the process as I understand it. This is 3/8" ID tubing which goes in the 1/2" hole on the flaring tool and uses the 1/2" die.
Place the tubing in the flaring tool and use the cutter to ream out a slight bevel on the interior.
Name:	ImageUploadedByAirstream Forums1405626836.145534.jpg
Use a fine file to smooth any burrs.
Name:	ImageUploadedByAirstream Forums1405626931.858463.jpg
Line up the top of the tube with the height of the outer ring on the die and tighten the wing nuts.
Name:	ImageUploadedByAirstream Forums1405627421.508224.jpg
The die goes in the tube
Name:	ImageUploadedByAirstream Forums1405627461.935697.jpg
The tool compresses the die until the die is flush with the top of the tool
Name:	ImageUploadedByAirstream Forums1405627657.603780.jpg
Remove the die and then make the 2nd flare with only the conical tool.
Name:	ImageUploadedByAirstream Forums1405627824.737264.jpg
This is what it looks like when you have the die crooked.
Name:	ImageUploadedByAirstream Forums1405627870.609339.jpg
This is what it looks like when it is centered properly.
Name:	ImageUploadedByAirstream Forums1405627943.611832.jpg
Now to do it on some real plumbing and drill some holes in the floor.
Old 07-17-2014, 06:57 PM   #345
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Looks like you've got the copper tubing down no problem. I used 3/8" tubing branching from a 3/4" Black Iron main header, so the pressure drop and flow restriction is minimal, but I also do everything overkill. Honestly, the one thing I didn't want to restrict was the stove, because I like my coffee and the faster I can boil the percolator, the better.
Your flares look great, you didn't even need to practice
BTW, I laughed at the recycle joke. The logic is flawless...
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 07-17-2014, 08:49 PM   #346
DFlores's Avatar
1968 22' Safari
Double flares, more overkill perhaps?
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-17-2014, 09:03 PM   #347
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I believe that double flare is the standard for RV LPG copper lines.
Old 07-17-2014, 09:08 PM   #348
DFlores's Avatar
1968 22' Safari
I have used the double flare for high pressure applications, like my Jeep brake lines, but was unsure of the need in a low pressure system like LPG, thus my question. I am currently running lines thru the floor prior to cabinet building.
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 07-17-2014, 09:14 PM   #349
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I think the need arises from the durability of the double flare to vibration. I agree that pressure is not the issue. I am basically quoting Lewster on this and he has way more experience than me.
Old 07-22-2014, 11:24 PM   #350
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Attached the switching regulator the other day. Click image for larger version
Name:	ImageUploadedByAirstream Forums1406088967.784780.jpg
I am running 1/2" OD copper straight from there to appliances. Below each appliance there will be a T to a 3/8" copper line which will go through the belly pan and floor straight to the appliance. My super cheap custom bulkhead fitting goes through a 7/8" hole in the floor and bellypan. It is made from 1/2" conduit and a sawed off union fitting.
Name:	ImageUploadedByAirstream Forums1406089225.092779.jpg
ID:	217202. I simply glue one cap in place, run a bead of Vulkem around the lip and run it through the hole.
Name:	ImageUploadedByAirstream Forums1406089247.199747.jpg
Then the other cap is glue in place while squeezing the whole thing together. I usually leave the end long and cut it off with a back saw after the glue is dry. After I run the tubing through I will squeeze in some sealant that doesn't mess with copper.
I've run the 1/2" line so far and installed 3 bulkhead fittings for the fireplace, the stovetop and the water heater. I've run the line for the stovetop. Now I need to run the 3/8" line for the water heater and fireplace.
1980 caravelle, 20', caravelle
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 11:44 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 08:36 PM
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 11:41 AM
old flange flush with new subfloor? valontjej Waste Systems, Tanks & Totes 10 03-13-2012 12:52 PM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 10:21 AM
