Old 04-25-2014, 07:43 AM   #309
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Originally Posted by timzog View Post
Some photos of the completed exterior outlet. I used a 20 amp receptacle and an exterior gasketed cover.
Attachment 210392
Attachment 210393
Attachment 210394
Timzog, I like the look of your exterior power supply fixture. Is the exterior housing a stock item that came with your coach or is it available elsewhere? I have a 56 Flying Cloud, and I want to install an exterior curb-side power supply.
Thanks for your very informative thread.
Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 04-25-2014, 08:27 AM   #310
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Hank
Thanks Hank,
I got the outlet cover from Lowe's for about $4 so I think it should be easy to find one like it at any hardware store. A regular outlet doesn't fit in the fixture as it comes from the factory. There is plenty of room for the box on the back side, but the screw holes on the box that accept the screws from a standard duplex outlet do not line up with the space in front. I had to file away about 1/8" to make room for the screw holes. The only other modification was a few 1/8" holes to accept the pop rivets to attach the box securely. After that, it was just like installing any other outlet. I really like the way that outlet works now. The standard exterior door is going to protect from any direct water intrusion and the gaskets on the new outlet cover will be additional protection. Of course, this will be on the load side of a GFCI which will be installed in the kitchen.
Good luck with your project!
I just looked at your question and realized that you mean the outlet assembly. I didn't install the exterior door, I only added the box, outlet, and outlet cover. When I was researching this, I saw that Little Girl Refurb purchased one for their project. Here is the reference... http://www.airforums.com/forums/f185...tml#post870540
Tim
timzog is offline   Reply With Quote
Old 04-25-2014, 08:32 AM   #311
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
attaching umbilical cord
Originally Posted by Wabbiteer View Post
Sorry, worked on 40-ton subway cars that'd do easily 50,000 revenue earning miles between thorough inspections and have seen some bizarre incidents. If you say its good enough so be it.
I'm still unsure the true footprint of your wire loom - and the protective sleeve perhaps has more strength than the wires combined.
In a perfect world a snag would withdraw the wires from the crimps if the side-acting forces did not allow friction build up to yank the entire assembly loose. (EDIT: The insulation should be mechanically anchored by something at each crimp on anything that sees vibration, flexing copper goes brittle even on teeny repeated motions) And the sleeve would simply slip through the bulkhead conduit fitting you implemented - but a crease/pleat at the sleeves bend would likely friction weld it enough the whole show would go into motion.
Again - I don't know your blueprint, just asking if you prepared for catching a 40-pound retread casing with your below-skin wire loom.
So I think my plan is going to be to secure this as tight and low profile as possible on the outside and add a few anchor points on the inside. Thanks as always for the well intentioned suggestions!! I only ignore you sometimes because I'm already too far in to take advantage of your suggestions
Old 05-02-2014, 09:10 PM   #312
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Some more progress.
Built the rest if the box to protect the water pump
Name:	ImageUploadedByAirstream Forums1399086125.084207.jpg
Name:	ImageUploadedByAirstream Forums1399086150.041748.jpg
Built a lid for the bottom bunk storage
Name:	ImageUploadedByAirstream Forums1399086205.564948.jpg
The rear section is hinged on the straight edge and makes a nice storage space.
Bought a 30" brake from HF for $40
Name:	ImageUploadedByAirstream Forums1399086304.840667.jpg
This was really useful n the construction of the lower bathroom cabinet...
Name:	ImageUploadedByAirstream Forums1399086364.003044.jpg
Name:	ImageUploadedByAirstream Forums1399086402.111309.jpg
I used the flat square piece of particleboard to make sure that the door opening was square and parallel.
Made a template for the top and tried out the Seadog sink to see how it feels...
Name:	ImageUploadedByAirstream Forums1399086517.046764.jpg
I then added the light switches for the bath. There are 3 lights, one very low level led light for a night light and two super bright LEDs. I also added a 12v outlet.
Name:	ImageUploadedByAirstream Forums1399086633.743165.jpg
Name:	ImageUploadedByAirstream Forums1399086649.772749.jpg
Old 05-02-2014, 09:15 PM   #313
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
1980 Caravelle Shell Off Renovation
I also completed the 110v outlets and they all work. My wife suggested that we go with black outlets. I had to order the shallow Leviton GFCIs and black 20a outlets, but I think black was the right call.
Name:	ImageUploadedByAirstream Forums1399086865.165846.jpg
Name:	ImageUploadedByAirstream Forums1399086906.520010.jpg
Old 05-13-2014, 09:17 PM   #314
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Working on the plumbing vent. I have an aluminum fitting in the outer skin, but needed to connect it thought the inside and seal to the inner skin. I found that 1 1/2" PVC would fit on the fitting so I made a ring out of .032 aluminum and split it to fit around a 1 1/2" vent 90 fitting. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400037713.935547.jpg
I attached this with a bunch of 1/8" pop rivets.
Name:	ImageUploadedByAirstream Forums1400037776.401227.jpg
Name:	ImageUploadedByAirstream Forums1400037794.509223.jpg
Old 05-13-2014, 09:31 PM   #315
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Working on the window trim.
It was painted black and I didn't like it. I sanded it down with my random orbit sander and 120 grit paper. I think they look way better. Here is the before...
Name:	ImageUploadedByAirstream Forums1400038034.446146.jpg
Here is the after...
Name:	ImageUploadedByAirstream Forums1400038085.138250.jpg
Working on the window hardware before I realized that you can't get any parts for the latches. Ended up only having four latches that actually had enough threads on the crappy pot metal piece to work.
Name:	ImageUploadedByAirstream Forums1400038111.586873.jpg
Spent $35 a piece for new latches. Ouch!!
Worked on the curved front window closeouts. They had a bunch of extra holes and the paint was pretty ugly. Sanded them down by hand.
Name:	ImageUploadedByAirstream Forums1400038436.406838.jpg
Used bondo to patch the holes and sanded it with 220 grit paper.
Name:	ImageUploadedByAirstream Forums1400038540.702562.jpg
Painted with several coats of plastic spray primer and several coats of silver enamel.
It is certainly not a pro paint job, but they look a lot better, I think.
Name:	ImageUploadedByAirstream Forums1400038720.367128.jpg
Old 05-13-2014, 09:48 PM   #316
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Bought vinyl sheet flooring. Going for a wood grain look without the potential for water damage.
First cleaned the floor with soap and water and let it dry.
Scraped off any gook and sanded with the random orbit sander and 120 grit.
Last chance to gaze at the beauty of the aluminum
Name:	ImageUploadedByAirstream Forums1400039128.093887.jpg
The little circle in the floor is a table leg support hat is mounted under the floor. I capped it with a very tight fitting 1/8" plate circle and glued it in with Vulkem. I actually had to hammer it in to make it fit. I added a 1/8" neodymium magnet so that I could find it if I decide to use it later. This is from the street side wall.
Name:	ImageUploadedByAirstream Forums1400039399.218573.jpg
This is from the front of the wheel well.
Name:	ImageUploadedByAirstream Forums1400039467.582653.jpg
Made a template from heavy craft paper.
Name:	ImageUploadedByAirstream Forums1400039598.163550.jpg
Laid the template upside down on the backside of the vinyl and taped it down. Cut it with a brand new razor blade.
Name:	ImageUploadedByAirstream Forums1400039665.583913.jpg
Laid it out in the airstream and installed it with double sided flooring tape at the edges and high impact areas. Photos to come soon.
Old 05-14-2014, 05:41 AM   #317
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Wow! It looks fantastic! You've been busy--keep up the great work!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-14-2014, 11:12 PM   #318
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Laying out kitchen cabinets. It is interesting trying to establish a flat reference point.
Name:	ImageUploadedByAirstream Forums1400131112.899258.jpg
My plan for the cabinets is going to be an aluminum frame attached to the floor and wall with wood drawer faces and doors. I am imagining building drawers out of 1/4" plywood with aluminum angle reinforcements at the joints. I found the KV 8400 RV drawer slides that claim to stay shut even in moving vehicles. I may buy one pair and run some tests.
Old 05-15-2014, 09:54 PM   #319
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Here is the floor.
Name:	ImageUploadedByAirstream Forums1400211843.306563.jpg
I made some more progress on the kitchen cabinet. I focused on making the outer top corner square and plumb and locked it all down by adding some 1/16" plate to the corners. Once I got the top planar and square I was able to start adding the rest of the frame. It is split into 3 sections. The left will be a DC fridge with a Danfoss compressor- either a dometic CR or an Isotherm Cruise. The middle section will be drawers and the right section will be the sink cabinet with the garbage can underneath.
Here is the first beer on the future counter. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400212434.426191.jpg
Old 05-19-2014, 09:55 PM   #320
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
No narrative, but some progress in picture format.
Name:	ImageUploadedByAirstream Forums1400557792.961376.jpg
This is where the sink will go.
Name:	ImageUploadedByAirstream Forums1400557859.991346.jpg
This is the mostly framed out cabinet complete with interior partitions. The end will contain a wood panel, probably cherry veneer 1/4" plywood.
Name:	ImageUploadedByAirstream Forums1400557952.536392.jpg
These are the curved panels I put in to partition off the water heater from the under bed storage area. The curved panels are super strong!
Name:	ImageUploadedByAirstream Forums1400558030.484069.jpg
The new axle awaiting some more research on how to install it.
Name:	ImageUploadedByAirstream Forums1400558117.796446.jpg
One more view of the rapidly shrinking space.
Old 05-26-2014, 12:40 AM   #321
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Name:	ImageUploadedByAirstream Forums1401085531.803958.jpg
This is the bed platform going in. I used IKEA bed slats at 4" spacing supported in the middle by a 1" aluminum square tube.
On the half over the water tanks, I attached 4 or 5 of the slats to 1/2" angle which is attached to the supports by machine bolts with thumbscrews. This will allow for sections to be removable for access the the water tanks and pump.
Name:	ImageUploadedByAirstream Forums1401085759.350122.jpg
The outer edge is supported by a 1x4 piece of cherry screwed onto a 1 1/2" x 1/16" angle.
The assembly rests on a 1" angle which makes he perimeter of the bed as well as a 1/8" x 1 1/2" angle piece attached to a rib with 3/16" rivets.
Name:	ImageUploadedByAirstream Forums1401086047.481195.jpg
ID:	212857 Click image for larger version
Name:	ImageUploadedByAirstream Forums1401086076.593958.jpg
Since the cleats are all laminated with a curved shape, it makes the bed a bit more resilient and stronger. Thy are attached to the supports with 1/2" x 1/8" rivets.
Name:	ImageUploadedByAirstream Forums1401086203.827570.jpg
We got the mattress at IKEA. It is a full. It mostly fits the space, but bunches at the curved corners. I may need to remove a spring in those spots or strap it down.
Name:	ImageUploadedByAirstream Forums1401086291.598797.jpg
Name:	ImageUploadedByAirstream Forums1401086330.645344.jpg
Name:	ImageUploadedByAirstream Forums1401086352.821701.jpg
The mattress is 74" long but the bed space is closer to 84" long. The rest is easily made up with pillows. It is very comfy.
Name:	ImageUploadedByAirstream Forums1401086436.144000.jpg
Old 05-31-2014, 09:09 AM   #322
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Wired up a switch under the bed to bring battery power to the running and reverse lights.
Name:	ImageUploadedByAirstream Forums1401548722.994071.jpg
Name:	ImageUploadedByAirstream Forums1401548751.860294.jpg
Should be nice in camp.
I replaced the porch light with two LED pads from LED4RV. One is a bright white 42 LED pad which is really bright and efficient. The other is a warm white 24 for more gentle light. They each have their own switch.
Name:	ImageUploadedByAirstream Forums1401548886.137841.jpg
The bright one.
Name:	ImageUploadedByAirstream Forums1401548920.922572.jpg
The warm one.
Name:	ImageUploadedByAirstream Forums1401548952.937364.jpg
Both together.
They put out a lot of light.
1980 caravelle, 20', caravelle
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 10:44 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
old flange flush with new subfloor? valontjej Waste Systems, Tanks & Totes 10 03-13-2012 11:52 AM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 09:21 AM
