Old 05-26-2013, 11:03 AM   #211
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Originally Posted by timzog View Post
After way too much thinking about it, I decided to put the bulk of my wiring in conduit. I like the idea for safety as well as flexibility. I will have a 12V set and a 110V set. I am using 1/2" PVC for everything and will use THNN stranded wire in various thicknesses depending on the loads and breakers. Most of it will be 12 or 14awg. The solar wire will not be in conduit. I splurged and bought red and black #6awg stranded wire for the connection between the roof and the charger. I am betting that #6 will be enough to handle all the solar panels I could ever fit on my roof so I think I only have to do that once. Here's a poor pic of most of the curbside conduit. You can't see that it continues to the roof and will be the primary path for the main lights and power to the fans as well as to the cabinets above the front bed. I am using the pull through connectors as little mini J boxes for the 12V side and access points. I'll plan on making some shiny aluminum covers for them after I put on the interior skins. The top path is the 12V and the bottom path is the 110V. The power center will reside just behind the wheel wells. Has anybody tried the all in one power centers that include 110V and 12V distribution and a converter? Seems like it would provide a nice clean installation to me.
Man, I'm glad I just read this!
I'm a Newby doing a shell off. I just bough a roll of reflectix. I have not began wiring yet. Are you blogging any of your work? If not, is be happy have you advise me on this.
I'm wanting to insulate my Ambassador and put up a solar panel. To stay off the grid as much as possible. What can you tell me??
Rowdy
rowdyATX is offline   Reply With Quote
Old 05-26-2013, 11:08 AM   #212
rowdyATX's Avatar
1961 28' Ambassador
Originally Posted by mutcth View Post
Wow! Those trailers actually exist?!? I thought they were only a figment of brochures and a picture or two on Vintageairstream. Love that floorplan and all the windows...
When you mentioned the Caravelle on the VAP I thought it was a 20' like my Minuet. I'd love to see photos too if you don't mind.
Tom
Hi Tom.
I'm starting at ground zero. What floor plan did you go with? Do you have any pics of options. I have a 28' Ambassador and. 22' Cloud. I'm in so far over my head!
Rowdy
Old 05-26-2013, 07:24 PM   #213
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Rowdy
Hey Rowdy,
I d be happy to tell you anything I can, but I am no expert- just learning as I go like most people here. How far along are you on the shell off? I've got a lot more pictures than just the ones I posted. For the solar panel, I used a Blue Sea pass through to facilitate the wiring and used #6 stranded wire to connect to my future battery location and the roof. If you are going to have more than 400 watts of solar panels, you may want to go even bigger. Best of luck.
Tim
timzog is offline   Reply With Quote
Old 05-28-2013, 06:52 AM   #214
rowdyATX's Avatar
1961 28' Ambassador
The shell is framed and I have disconnected the shell completely. If I can find a buddy, I am going to lift it and pull the trailer out this week, and get the trailer repaired.
Did replace your axles?
Old 05-29-2013, 08:38 AM   #215
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Good luck with lifting the shell. I ended up raising the shell myself inch by inch with jacks. I put 4 posts solidly into the ground around the perimeter and jacked up the shell in the front until I could get a sturdy board under the shell and on top of the chassis. Then I secured that board to the front two posts and did the same to the back. Then I raised the front 3 more inches and secured it and then did the same to the back. Once I got it high enough, I rolled the chassis out and secured the shell to the posts and kept it there for six months.
I would suggest that you create your own thread about your project and post lots of pictures. You'll get lots of advice from lots of people that way. I have not yet replaced my axles but it is on my list for this summer.
Old 05-29-2013, 11:54 PM   #216
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Ive wanted to be able to run the fantastic fans when I am working inside so I bought a cheap fuse block and am going to try to hook it up to the Univolt and see if it works. I was struggling to figure out the polarity of the power cord since it had been cut off long ago. I made a guess and wired it back together. The ground was obvious. My plan is to ground the Univolt to the trailer floor, hook it up and test the voltage output on the 12V side. If I have the black and white wire backwards on the 110V AC side, would that be dangerous?
Old 05-30-2013, 07:56 PM   #217
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Plugged in the old Univolt and it did hum a bit but it delivered about 13.5 volts so it should be perfect to run fans and to test out some light scenarios. I'm going to buy a couple of LED lights from led4rv like this one... http://led4rv.com/index.php?main_pag...roducts_id=243
I already bought a few from Imtra that I want to check out. The smd based LEDs are so much more efficient it will be tough to use anything else.
Old 06-11-2013, 05:26 PM   #218
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Insulating!!
So far I have installed 7 4x8 sheets of 1" polyisocyanurate board into my Caravelle. I have some pics to share later. I think I have two more sheets or so left to install so I have to go back to HD since I only have one left. It is slow going but the noise reduction is incredible and I think will be worth it.
Old 06-11-2013, 05:34 PM   #219
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Insulating!!
One thing I've noticed as I wrap up the insulation is that the inside temperature is very manageable even in full on Utah June sun. The inner surface of the insulation is not even slightly warm but the ribs are super hot to the touch. So last chance to inspire me with your great ideas for a thermal break material for the ribs. I've seen several ideas but haven't seen much in the way of "I tried 'this' on my airstream and it worked ...."
Thanks in advance.
Tim
Old 06-12-2013, 12:45 PM   #220
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I've got a letter into sales at PolymerSheet.com asking about recommendations on .020 to .0625" sheet polymers..
High Density Polyethylene
Ultra High Molecular Weight Polyethylene
Low Density Polyethylene
Polypropylene
etc..
Old 06-12-2013, 01:42 PM   #221
rowdyATX's Avatar
1961 28' Ambassador
Have you looked at putting reflectix against the outer wall reflect the ultra violet sun rays.
It should keep the exterior from getting hot.
Old 06-12-2013, 08:10 PM   #222
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I installed a layer of reflectix closest to the outer skin followed by a small air gap and then the polyisocyanurate foam. This is really effective at blocking heat transfer through the bulk of the walls (but not the ribs) as well as blocking sounds. My understanding is that the ribs get hot because the outer skin gets hot and that the thicker aluminum of the ribs transfers heat efficiently to the inside. There is no way to keep the ribs from being the same temperature as the outer skin without installing some kind of insulator between the outer skin and the ribs. Doing that would require drilling out every rivet and reinstalling them hoping that the holes would line up again.
It is amazing how much cooler the inside is now after I've installed most of the insulation, but the ribs do get so hot in the southwestern sun that you could burn yourself.
Tim
Old 06-12-2013, 08:23 PM   #223
rowdyATX's Avatar
1961 28' Ambassador
That's good to know.
So can you tell me exactly how you insulated you AS? What type of insulation? And how did you adhere the reflectix to the aluminum? And any pics or advice on wiring...
I'm taking my trailers to have them sandblasted and repaired this weekend so I can coat them and put new axles on them. Since I won't get them back for a while, I'm thinking I could go ahead and install the reflectix. At least the ceiling...
Old 06-14-2013, 08:48 PM   #224
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I cut strips of reflectix 1 to 2" wide and attached them to the outer walls with 3M adhesive. This was a spacer layer to provide an air gap. I then cut reflectix to fit the shape of each opening and glued it to the reflectix spacers. I then used aluminum foil tape to seal all the pieces of reflectix to the ribs and provide a vapor barrier. I then cut 1" thick polyisocyanurate(foil on both sides) to fit each opening and attached them into place with foil tape flush to the inside surface of the ribs. Ill try to remember to take some pics. Where there were seams between panels (not at the rib), I used spray foam to connect the pieces and improve the fit.
For the wiring, I ran 1/2" PVC conduit along both sides of the airstream for both 12v and ac power. I put boxes wherever I wanted outlets or switches. I used conduit pull boxes throughout as access points (I'll cut out the inner skin where they are and make a simple oval cover held on by screws out of aluminum). This will allow me to add circuits as needed. I put in a 30A marine inlet on the back left and ran a conduit under the floor to bring power to the power center and batteries which will be in the back rear. I ran a couple wires front to back along the ceiling without conduit just in case as well as a couple wires along the ceiling side to side for lights from a switch box. I'm going to take good,measurements so that I can find the wires after I put on the inside skin.
Good luck. I would seal the crap out of everything before you do any insulation. Seal every inside seam with Vulkem and seal outside with Parbond. Go out in a big rainstorm and watch very carefully for any sign of leaks. Also think about any new exterior penetrations like vents or inlets and do them while you can reach both sides of the outer skin.
1980 caravelle, 20', caravelle
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 10:44 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
old flange flush with new subfloor? valontjej Waste Systems, Tanks & Totes 10 03-13-2012 11:52 AM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 09:21 AM
