Old 10-25-2012, 07:11 AM   #141
1981 31' Excella II
New Market , Alabama
Your flashing should work as long as there is nothing under it to funnel water back inside. Did you say you were not going to put the bumper box back on?
Perry
Old 10-25-2012, 08:14 AM   #142
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Perry
If I do build a box there, I will give it an inch or more gap so that water can run past. I haven't decided how to finish off that part. I don't have a bumper at all so either need to buy or fashion something.
timzog is offline   Reply With Quote
Old 10-25-2012, 09:45 AM   #143
1981 31' Excella II
You probably have enough scrap aluminum to make a new box that is self contained instead of the original design that used the bottom skin to finish out the bottom of the box. I am in the same boat. I think I will make the frame rails just a little longer to make room for a new box.
Perry
Old 11-07-2012, 09:15 PM   #144
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Working on wheel wells. Step 1 is curving some 1/8" aluminum to make a 30" long x 11 3/4" wide x 13" tall arc. I screwed a cleat to a board and started arcing a 48" x11 3/4" sheet with bar clamps. It seems to be taking this radius well with kinking or showing signs of stress. I'm going to let it sit like this for a day and see how much it relaxes. I am still figuring out how to attach the sides. Either I will hammer a thinner sheet into an angle or I will kerf an existing angle to make the bend. I thought about a square form but I couldn't resist trying to make the smooth radius bend. I may regret this, but I was impressed by how nicely it took the bend.
Old 11-08-2012, 02:11 PM   #145
1981 31' Excella II
1/8" man that is thick. That might even stand up to a blowout.
Perry
Old 11-08-2012, 09:02 PM   #146
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I tried a couple of ways to make the rounded wheel wells but gave up. Is there any reason not to just build a rectangular box?
Perry, I hope you are right and that I never find out
Old 11-08-2012, 09:41 PM   #147
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Why don't you take your metal to a sheet metal shop and let them bend it for you? Or take your old wheel wells and just let them fabricate them.
desertair27 is offline   Reply With Quote
Old 11-09-2012, 03:17 PM   #148
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
That is a good idea, but I'm stubborn and cheap and like to do things myself. Also, I haven't wasted enough money or time yet to call in somebody who actually knows what they are doing.
Tim
Old 11-09-2012, 03:28 PM   #149
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Our Hero!
Okay, I have ulterior motives... I'd like to see a bullet-proof and repeatable wheel well design come about from this...
Old 11-09-2012, 05:47 PM   #150
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Tim
That's funny Tim, I'm the same way.
Good luck with it! I'll be watching.
Mike
Old 11-10-2012, 09:58 PM   #151
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Not getting as much done as I had hoped this weekend.
Old 11-17-2012, 01:22 PM   #152
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
So I've decided to just build a rectangular box for the wheel wells. It will be 1/8" plate aluminum all around except the outside face which will be 1/16" or thinner. I'll cut the thinner outside piece to match the shell cutout on the bottom and then rectangular on the other three edges. The original wheel well trim should fit over the thickness of the shell and the new thin wheel well. All the edges will be joined with 3/4" angle and buck rivets wherever I can reach. Not a great explanation but I'll show some pics as I mock it up hopefully later today. I am currently at a place called Kangaroo Zoo where my kids are attending a birthday party so if I am not fully coherent, I believe I have a valid excuse.
Tim
Old 11-17-2012, 02:16 PM   #153
Wabbiteer's Avatar
1972 29' Ambassador
Said box to act as inner or outer or replace both WW tubs?
On my '73 wells, with the two layers of plastic tubs crammed with an inch of pink fiberglass, it'd be easy to reuse the old exterior black tub as tire-blow-out cushion by tacking it in the aluminum box hollow, but that leaves a Kangaroo Pouch effect in the air spaces left unfilled...
I wonder if just gluing up an inch of foam board on the tire side of the aluminum boxes would provide enough cushion?
Old 11-17-2012, 07:53 PM   #154
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I am planning on just having one layer of aluminum. I was thinking about just wrapping the box with foam or prodex. I was also thinking about painting the tire side of the box with truck bed liner material. I don't know that is insulating at all but I think it should make it very tough. I don't see how the plastic tubs are very strong at all and I have a hard time imagining how a tire blowout would break through 1/8 aluminum plate but I have never seen one and I guess there is a lot of momentum in a tire at 60 mph.
I wonder if you could spray foam on the tire side of the box to insulate and cushion and then spray the truck bed liner on top of that to give it a tough protective casing.
1980 caravelle, 20', caravelle
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 11:44 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 08:36 PM
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 11:41 AM
old flange flush with new subfloor? valontjej Waste Systems, Tanks & Totes 10 03-13-2012 12:52 PM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 10:21 AM
