Old 09-07-2011, 07:21 PM   #1
1967 26' Overlander
Mosier , Oregon
Starting to restore '67
Hi- I am a newbee to Airstream restoration and looking for general info and resources for construction and restoration. Right now I am trying to learn about the water tank system and how to replace them.--Any help helps.
Thanks-Greg
Time2Shine is offline   Reply With Quote
Old 09-07-2011, 07:58 PM   #2
Thanks-Greg
The original water tank is available for your 67.
All the other parts for the water system are available as well.
Check valves, pop off valve, possibly parts for the water pump, depending on the make and model, are also available.
Old 09-07-2011, 10:52 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Welcome to the forums!
Thanks-Greg
This might help.
Click on it to make it big.
Name:	Airstream manual 57.jpg
ID:	139655   Click image for larger version
Name:	Airstream manual 15g.jpg
Name:	Airstream manual 15h.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-08-2011, 05:44 AM   #4
65CV's Avatar
Western , Massachusetts
You can consider something like the tank and pump combination I used:
26 Gallon Marine Water Tank 52 X 11.75 X 10.75 04-W1113.
... and the pump...
Shurflo Revolution Pump
65CV is offline   Reply With Quote
Old 09-11-2011, 09:55 AM   #5
1969 27' Overlander
Albuquerque , New Mexico
Location of systems, etc.
I'm in the same situation as Time2Shine:
I just bought my '69 Overlander, and am getting ready to start repairing the Utility Systems.
Where can I obtain a service manual for the trailer, showing location and routing of devices?
Silverleeper's post shows several diagrams, including the water system.
I haven't even located the water tanks, etc, yet.
Where are all these located, and how do I physically get to them?
Are they under the floor? How do I access the water and waste tanks, and plumbing?
Is there a "Chilton's" type manual for Airstreams, or original factory service manuals, etc?
Thanks!
edglenn is offline   Reply With Quote
Old 09-11-2011, 10:23 AM   #6
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
I am just about to button up my overhaul of my 1968 GT. I used the factory owners manual, you can find copies of yours if you look on Ebay. All manuals can be found as copies, sometimes originals. Also there is a very good repair manual covering 3-4 major size models, 70's-80's. I am on year 2 to finish her up. Check the photos under trailers-Globetrotter to help.
Randy
Randy Gates is offline   Reply With Quote
Old 09-11-2011, 11:16 AM   #7
Thanks!
Service manuals are available starting in 72-73.
They are very close to your 69.
Old 09-11-2011, 04:24 PM   #8
1967 22' Safari
1960 Caravel
Images: 8
Try the Mother Ship...https://store.airstream.com/index.php?cPath=51
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 08:25 PM
1970 Airstream 32 ft Camper Sovereig for use or restore eBay Watch Airstreams on eBay 0 04-28-2011 08:10 PM
'73 tradewind switches and starting the furnace constructor Lights - Interior & Exterior 9 01-25-2011 01:28 PM
