Old 05-09-2010, 10:04 PM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Some progress, but not much.
The subfloor is in, 1/4" hardwood sheeting over the plywood sub-sub floor. I've sealed the subfloor with an outdoor waterproofing (Behr) sealer. The old plastic wheel wells are out. The rear bed ("short queen") is framed in. I went with poplar. It's not a particularly strong wood, but it is very light. The frame itself is mostly 1x3 with 2x2 supports. I thought about putting in a floor covering under the bed, but I think the sealed hardwood will work fine and it will allow me to inspect the wood.
I haven't attached the bed frame to the floor yet. I'm still fussing with a few things. It's not cabinetry, but it will hold. Standard "glue-and-screw" construction.
I'm going to leave the plywood panels off until I'm done messing around with the wiring. I'm relocating the AC fuse box to allow better access from the rear hatch and I'm mounting the convertor on an elevated sheet of thin hardwood plywood... I figure it can't hurt.
Once the "under bed" nonsense is done, I'll start framing in the bathroom. I have to dry fit the head and start playing around with the shower pan floor.
I've got a rough template for how I'll do the wheel wells. The curbside (starboard) well will serve as the bench seat for the shower and bathroom storage. The streetside (port) wheel well doesn't have to be quite as load bearing. I picked up Reflectix to insulate the wells. Oh, and I'm also routing some ducting through the bathroom, using the space between the top of the metal well and the bottom of the wooden bench seat.
hampstead38 is offline   Reply With Quote
Old 05-10-2010, 12:04 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Think I've read about your wheelwell plan before. Sounds like a well thought-through alternative! Pictures is gooder.
I've used poplar in other applications and seems to be a good wood. Are you using Krex or biscuits for any joinery?
5 meter Langford Nahanni
Old 05-10-2010, 08:03 AM   #3
1967 26' Overlander
Upperco , Maryland
My wife has the camera. I'll have her download some pictures for me. As far as biscuits, I'm treating this as "framing" rather than "cabinetry." It's not bad for a guy who grew up think carpentry was a unit of 2x4s, a five-gallon bucket of 16-penny nails and a chain saw.
Poplar isn't a bad wood, but it's not attractive. I'm using it because it's very light and strong enough to do the job. There's only one "panel" on the bed frame anyone will see. My plan is to cover it with a thin birch ply.
My overall concept for the trailer is to use the same birch ply for all of the exposed wood. I'm also make all of the panels "removable." I'll use small brass wood screws. If I need to get at something... back out the screws, zut, zut, zut, and remove the panel. I'm guessing the only place I'll use biscuits or other joining approaches is in the galley cabinets and countertop. Since I've never actually built any cabinets, that should be a rodeo.
As for the bed frame, it's the only real "load-bearing" structure. And since I'm the heaviest thing in the Airstream... it has to take a bit of load. I'm going to use the same basic concept on the top of the bed frame (plywood). There will be four panels. With the Sleep Number bed (deflatable), I'll be able to remove any of the panels to get at things underneath (like the convertor, 110v breaker box, 12v fuse box, etc.
Old 05-10-2010, 08:30 AM   #4
Pocket-holes are a great way to frame up Airstream cabinetry. Very easy even for novice DIYers (or those recovering from 2x4 and 16-penny nail construction ).
The "Kreg" jig is the most popular for pocket-holes, but there are other brands available that will do the same thing.
Old 05-10-2010, 12:18 PM   #5
1967 26' Overlander
Upperco , Maryland
Well, Marcus, I have no illusions that anyone will mistake me for a cabinet maker. I could have done pocket holes for the bed, but I made a command decision that I wasn't going to worry about looks with the framing. The bed frame simply has to keep my suppine carcass (and bed) off the floor of the trailer.
I don't know "pretty," but I do know "sturdy."
To have a flat face to mount the birch, I'm going to fabricate some additional "legs" tonight. They will be spaced about the width of the rear access hatch on both sides. I also need to add some stringers running fore to aft. At the minimum, I think one 1x3 along the centerline, but I'm constantly at war with my inner over-engineer.
The general idea is to have a light birch door to allow access to the forward underbed storage age. I'll have enough room for plastic storage tub filled with mostly light stuff like linens and extra clothing.
I'll shoot a few more pictures after the bed frame is finished... oh, and I need to hit the floor with some more waterproofing, especially the place where I dumped the convertor.
Name:	bed frame.jpg
Old 05-18-2010, 03:29 PM   #6
1967 26' Overlander
Upperco , Maryland
Some things I think...
1. The Kreg jig is pretty darn cool.
2. Tolley's Creeping Crack Cure is good stuff.
3. The floor feels much better with the 1/4" of additional subfloor.
4. The problem with not doing wood work on a regular basis is that you have to make the same stupid mistakes you should have remembered making before.
5. It's hard to know exactly where to draw the line in compromising between weight and strength. I don't think the bed frame will fail as currrently designed... but it's always tempting to add "just one more...."
6. Cheap wood screws are exactly that and nothing more.
7. Glue is good.
Name:	Wheel well 23.jpg
Old 05-18-2010, 06:15 PM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Why don't you do a lift up section on top of your bed frame for storage? It would give you much more access to the underbed storage than a door in the foot of the bed would. You'd need a piano hinge or 3 regular hinges, and gas lifter thingys, (or a stick).
You might want to divide your underbed storage into sections - one for access from inside the trailer, and one for access from the rear hatch. That way if things shift, they don't go too far out of reach, requiring you to crawl in!
Just some suggestions.................
Kay
Old 05-18-2010, 07:45 PM   #8
1967 26' Overlander
Upperco , Maryland
Thanks, Kay.
The top of the bed frame will be all flat panels which will be removable. I'm not sure I want to do hinges. I like the ideal of being able to take out and replace panels.
I've already given thought to the rear access hatch. It's mostly there as a utility access rather than a storage area. I'm concerned about weight at the rear of the coach. I'll remount the breaker panel to allow better access and create some dedicated areas for other light storage.
Old 05-19-2010, 11:47 AM   #9
1967 26' Overlander
Upperco , Maryland
I had some feedback via PM on the bedframe. It isn't done yet. I'm adding more "legs" and cross bracing. As for the strength, the plywood panels will rest directly on the legs and bear the weight. There are 6 2x2s so far with another 6 to come. Because the 2x2 are poplar are only 17 inches long, they don't weigh much. The example I think of is a dining room chain. I can stand on one of our chairs to change a light bulb... rock solid despite very skinny legs. In fact, I think I could have our entire family stand on one chair if we'd fit. The most likely failure is lateral stress, i.e., leaning back.
Old 05-20-2010, 09:38 PM   #10
1967 26' Overlander
Upperco , Maryland
I wanted to take some pictures, but of course, the camera was out of batteries. I owe the folks looking at the Nature's Head composting toilet a few pictures. Here's the thing. The composting toilet needs to be vented but the roof vent is on the opposite side of the coach. I'm thinking about cutting a small vent hole in the wheel well. Overall, I think it would work. The Nature's Head uses a small computer type fan to move enough air to keep the compost working. My only concerns are screening the vent and make sure the "road dust" doesn't clog the screening. Food for thought, I suppose. Oh, the Reflectix does seem to work well insulating the wheel wells.
Old 05-21-2010, 04:47 AM   #11
Baltimore , Maryland
Photos, more photos... some of us are visual people and need pictures to understand all that hand gesturing.
Old 05-21-2010, 12:00 PM   #12
1967 26' Overlander
Upperco , Maryland
Well, because Frank can't see my virtual arm waving, I charged the battery and took some photos instead of eating lunch. The first is the genuine Nature's Head composting toilet. It is positioned in roughly the place it will, near the starboard wheel well. The second picture is the side view showing one of the two vents (circular hole).
Name:	NH front.jpg
ID:	103030   Click image for larger version
Name:	NH side view.jpg
Old 05-21-2010, 12:03 PM   #13
1967 26' Overlander
Upperco , Maryland
The vent issue
In this photo, you can see the small vent in proximity to the wheel well. The second photo is the vent tube/hose (provided for a sense of scale).
Name:	Vent plus well.jpg
ID:	103032   Click image for larger version
Old 05-21-2010, 12:07 PM   #14
1967 26' Overlander
Upperco , Maryland
And for a sense of scale
This is the NH, the wheel well, the pipe into the gray water tanks... provided to give a sense of the bathroom layout. When I frame in the wheel well, I'll use the Reflectix and leave space to run ductwork and the NH vent over the well and under the bench seat for the shower. The scraps of plywood sitting on the well were doing something, but I've forgotten what now. The second photo is the port wheel well with the Reflectix and the wheel well framing moved to one side.
Name:	Bath with NH.jpg
ID:	103035   Click image for larger version
A little progress... Anton66 1966-68 Caravel 8 07-24-2009 12:50 PM
polishing progress zanad Cleaning, Stripping & Polishing 14 06-23-2007 10:17 PM
Maintenance In Progress Andy R Forum Admin, News and Member Account Info 2 02-16-2007 04:01 PM
Progress? Over59 1960 - 1964 Overlander 7 12-19-2004 10:50 AM
