Old 05-06-2010, 12:40 PM   #15
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I would like to replace mine - any suggestions where to get the hardware. The PO took out the old one and screwed a peice of pexiglass in it's place.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 06-22-2014, 03:51 PM   #16
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Time for a new gasket
Originally Posted by TomW View Post
Hail took out my original solardome a couple of weeks ago. If you are looking for a well-made replacement solardome, I highly recommend InlandRV's.
Details of the replacement can be found here.
Tom
Eight years later, the solardome is holding out well. The sealing gasket... not so much, and it has already been replaced once.
The original gasket measures 1" wide by 1/2" thick, and, while six feet of it would only cost ~$4.20, appears to be only available from a source with a $20 minimum order PLUS ~$20 shipping charge.
17 feet of the same gasket material, albeit a quarter-inch narrower, is available from another source for about $20 delivered.
Since the solardome's sealing surface is only about a 1/4" wide, I have gambled $20 & ordered the substitution.
I'll keep you posted on how it works out.
Tom
Old 07-02-2014, 03:56 PM   #17
TomW's Avatar
1967 26' Overlander
Plan B
Okay, the new gasket material came in the other day, and it looks just like OEM other than being 1/4" narrower. I think it will work just fine as long as I am not clumsy about its placement.
I went to install it in preparation of our July 4th trip, and found that the old foam was in good shape other than the double-sided sticky tape succumbing uV.
I cheated & replaced the tape; will let you know how many rounds it goes.
Tom
Old 11-14-2014, 01:50 PM   #18
TomW's Avatar
1967 26' Overlander
No Problem
.. and it looks just like OEM other than being 1/4" narrower...
Well, I am just plain lazy - Here it is November, and the new gasket was just installed this past weekend. The Solardome is now weather-tight as well as one of the overhead vent fan covers.
Sealing was not a problem. The only issue is that the glueprint of the wider-than-it-needed-to-be original gasket is visible if one cares to stare straight up with a flashlight.
Success has been declared.
Tom
Old 03-20-2017, 01:38 PM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Hehr Lifters on Solardome
On this subject, my dome cover is attached with two Ladue vent lifters. One of them broke off on the outer side ..looks like it lost a nut over the bracket.
Do these new solardomes have the brackets in them for the lifters, or do I take the brackets off the old one.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
ALANSD is online now   Reply With Quote
Old 03-20-2017, 02:14 PM   #20
TomW's Avatar
1967 26' Overlander
Nope
Originally Posted by ALANSD View Post
...Do these new solardomes have the brackets in them for the lifters, or do I take the brackets off the old one.
My Solardome did not include any hardware. All metal parts needed were recycled from the old one.
Tom
Old 03-20-2017, 05:39 PM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Yep, thanks. I found out today when I pulled off the old one I would need to unscrew the brackets that the lifters insert into.
They seem to press in and that's all. Not sure why one popped out, but it got loose and that brought me back to this project. Started thinking about it two years ago. Other stuff got in the way.
Guess I will hit up Inland rv and order the smoky grey one.
1966 Overlander
AIR #005
Old 03-20-2017, 06:40 PM   #22
TomW's Avatar
1967 26' Overlander
I like a bright interior
...Guess I will hit up Inland rv and order the smoky grey one.
Oddly (to me) Andy badgered me about getting the translucent version.
I have never regretted my purchase.
Tom
Old 03-21-2017, 06:26 AM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
maybe I will get a discount on the grey- free shipping would be nice
The old dome lasted almost 50 years. IT finally cracked when a limb fell on it. My temporary repair last 2 years. But it was only a short term fix, I knew that going in.
We sat through hurricane like winds and rain in Florida for a day plus recently, and the messed up dome did not leak. Water did come in a one point through my refrigerator vent as the wind came from that the side of the trailer and pushed water over the vent and in. It was quite a mess as it rolled out from under the fridge.
1966 Overlander
AIR #005
Old 03-23-2017, 11:50 AM   #24
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Just ordered the IRV dome. Can't believe they get $55 to ship it.
I shipped an electric guitar for less that that!
Scalped!
1966 Overlander
AIR #005
Old 03-23-2017, 12:12 PM   #25
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Sorry to hear of the shipping charges. I ordered one from IRV years ago and it didn't fit. I sent it back. Ordered one from Colin Hyde and it fit perfectly plus I liked the product so much better. Good luck with your solardome.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-23-2017, 12:40 PM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
hope thats not the case. TOMW says his fit perfectly and he too has an Overlander.
1966 Overlander
AIR #005
Old 04-12-2017, 07:01 AM   #27
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
it has been 3 weeks since my order went in and still not received. I emailed and got no reply. I guess I made a mistake ordering from Inland RV..
Be forewarned.
1966 Overlander
AIR #005
Old 04-12-2017, 07:52 AM   #28
1974 27' Overlander
Baltimore , Maryland
Have you tried calling? In my experience, they answer the phone at Inland.
1974 Overlander In Progress
TheGreatleys is online now   Reply With Quote
Generator installed in Airstream flyfisher Generators & Solar Power 14 01-22-2004 07:48 PM
New Axle Installed. Success! DanLyle Axles 0 04-25-2003 12:00 AM
replacement airconditioners installed free wb13798 Mechanics Corner - Engines, Transmission & More... 1 04-16-2003 07:44 PM
Fan-tastic vent - has anyone installed one? wayner1239 Electrical - Systems, Generators, Batteries & Solar 14 03-21-2003 05:46 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 05:15 PM
