Old 07-11-2005, 12:13 AM   #1
JMGAZ's Avatar
'67 Gvwr...
Can anyone provide me the GVWR for a '67 Overlander International?
The A/S weight chart only lists the dry weight of their trailers. A '67 is 4180 + 450 tounge, which puts me around 4620.
I found an .xls spreadsheet that seems very helpful in calculating towing capacities. http://www.popupexplorer.com/files/T...yWorksheet.xls
Im crunching the #'s to try and remain around 80% GCVWR. Right now Im 85% on the TV and 75% on the coach (assuming 6500# GVWR).
JMGAZ is offline   Reply With Quote
Old 07-11-2005, 03:44 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Actual case example
From this thread:
Originally Posted by femuse
GVWR (Gross Vehicle Weigh Rating) is the value specified by the manufacturer as the recommended maximum loaded weight of a single vehicle. For a trailer this value is determined by the axle capacity and the coupler capacity. For example, a trailer will be rated at 5000 lbs. GVWR by the manufacturer if it has two 2500 lb. axles and a 2 inch ball coupler that is rated 5000 lbs. Loading the trailer to excess of the GVWR is not only unsafe, but is illegal.
Each of my 1967 Overlander International's Henschen axles is rated at 2800 pounds. Since my particular 2 inch ball is rated at 8000 pounds, this should make my GVWR equal to 5600 pounds.
Tom
Old 07-11-2005, 04:01 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Tom,
What I do for a unknown trailer GVW is take the axle capacity and add 10-12% of that to the total for the hitch weight...in your example that would be approximately 6200# .
My personal rule of thumb is GVW of trailer needs to be about 75% of vehicle towing capacity. If it is over that then I bring out the tables charts and calculators. FWIW I am currently towing a 31' Sovereign where the trailer GVW is actually 97% of towing capacity of my Tow Vehicle ...but I never tow anywhere near actual gross of the trailer and I limit myself to the flat lands and it handles it just fine. There is a tow vehicle upgrade in the near future....
Aaron
WBCCI #XXXX AIR #2495
Old 08-24-2008, 07:02 AM   #4
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Out of curiousity, I looked around. Colonial Airstream (a pretty big dealer) sold a '67 Overlander where the GVWR was listed at 5000 pounds.
http://www.colonialairstream.com/preowned/7863.html
I also found a little calculator that doesn't require Excel.
http://changingears.com/rv-sec-calc-...eight-tt.shtml
Just a few thoughts....
hampstead38 is offline   Reply With Quote
What's my GVWR rating? Janets Husband Axles 5 04-30-2004 09:01 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
wheel chair setup in GVWR bob.rita Tow Vehicles 4 08-02-2003 11:18 AM
Help GVWR Bubbla Our Community 1 05-19-2003 07:56 AM
Escalade-Hensley-25' Classic Kistler Our Community 25 02-12-2003 04:13 AM
