Old 07-19-2009, 02:16 AM   #1
2007 25' International CCD
Spring , Texas
Storage Shelf for back of 25' International
I am interested in making or purchasing a shelf for the back of my 25' International to store a generator and fire wood. Any ideas would be appreciated. Also, if anyone knows where I can purchase that would be even better.
Ken Michael is offline   Reply With Quote
Old 07-19-2009, 04:02 AM   #2
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
No excess weight on the back of an Airstream. This can lead to frame/shell seperation.
Fire wood and generators ride best in the truck bed.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 07-19-2009, 05:50 AM   #3
Kevin245's Avatar
1976 31' Sovereign
Upstate , South Carolina
Ken,
Welcome to the forum.
What you are asking seems reasonable and logical, but it is wrought with problems.
There is mixed opinions on the subject with regards placing light loads on the rear bumper, but the general consensus is don’t do it. A heavier load such as a generator, or such would likely (IMHO) create handling issues, and place significant stress on the frame.
The portion of the trailer frame that extends back from the rear axle is a giant lever. Think of it as a swimming pool diving board on wheels. Weights placed on the rear of the frame (AKA diving board) will want to bounce up, or down as you travel across bumps, or dips in the road. This places tremendous stress on the frame and shell, and transfers across the fulcrum point (axles) to the hitch point which affects TV handling.
This subject of placing loads on rear bumpers is discussed to varying degrees in the following posts.
Best of luck, and welcome again,
Kevin
http://www.airforums.com/forums/f464/receiver-on-back-of-a-s-travel-trailer-42072.html
http://www.airforums.com/forums/f209/bike-rack-rear-bumper-39529.html?highlight=bumper
http://www.airforums.com/forums/f477/looking-for-advice-about-rear-bumper-3482.html?highlight=bumper
"...the most confident critics are generally those who know the least about the matter criticised."
Ulysses S. Grant
Old 07-19-2009, 11:10 AM   #4
Spring , Texas
Thanks for the speedy reply. I am using a suburban for my tow vehicle and just can't figure out where is the best place transport the generator with all of the gasoline. In the vehicle or in the Airstream. I have been putting the generator (150 pounds) in the middle of the Airstream inside by the table, but am always in fear of the gasoline spilling in the Airstream. Then I am still trying to figure out where to put the generator in order to keep out of the rain while running. That is a whole nother issue. I was going to store on the back of the Airstream but I quess that option is out. I will probably make some sort of cover so the generator does not get all wet when we have rain down here in Houston.
Old 07-23-2009, 05:16 PM   #5
Walnut Creek , California
Have you considered converting it to propane. I converted my Honda because I hate the smell of gas. you could then put it in your suburban and not worry about the smell. There are other benefits such as better long term storage and you could t off of your trailers propane. You do get slightly less power though.
BoatBoy is offline   Reply With Quote
Old 07-23-2009, 05:21 PM   #6
Kevin245's Avatar
1976 31' Sovereign
Have you seen this?
Saw this in the classifieds today... Definately got my attention.
Ulysses S. Grant
Old 07-23-2009, 05:51 PM   #7
Spring , Texas
shelf idea
What is that. I solved my problem by selling my 3000is is record time on craigs list. 5hrs and 20 phone calls. I must have sold it to cheap 1300, becasue everyone wanted it. I purchased 2 Honda 2000i generators. No need to convert to propane because they burn such little gas, about half what the 3000i burns. I started them up and man these things are great. Lost of power from just one but with the parallel cable they are unstopable. I powered my 12000 btu window unit with just one with no problem. I hooked up the parallel cable to the other 2000i and tried the same air conditioner and with both on eco mode. The generators did not even surge. I plan on hooking up both to start my 13500 btu AC then turn one off. I keep my AC on highest setting so the compressor does no cycle. One 2000i will run with no problem but my 3000i would have trouble starting sometimes. I don't think I have a hard start kit on my AC but I think I will try to find one. If so I should be able to power the 13500 with just one 2000i. I spent 2050 for both generators with marine covers and the transfer cable. I purchased from a local place in Spring, TX. Great service and friendly people. My opinion is that for an RV with one 13500 btu AC unit the 2 Honda 2000i's is the best generator setup on the market.
Old 07-24-2009, 08:33 AM   #8
Is that a swamp cooler on the back?
Old 07-24-2009, 09:35 AM   #9
Kevin245's Avatar
1976 31' Sovereign
The ad says that it is a generator.
Ulysses S. Grant
Old 07-24-2009, 09:39 AM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The trouble that some people will go to to cause more problems. A quick fix is not the long term solution.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-24-2009, 10:29 AM   #11
Kevin245's Avatar
1976 31' Sovereign
I'd guess maybe 250 to 300 lbs (conservative)for the generator, plus another 100 lbs of power cable. Factor that by the distance away from the axles and I would guess this would create a noticable handing change in your TV.
Not to mention any frame issues.
When I taught motorcycle safety we covered the affect of handling changes when riders placed loads on factory luggage racks which were typically located behind the rear axle centerline. The ratio we typically used was 10:1. So for 1 lb placed behind the axle it took 10 pounds in front of the axle to ovecome the weight transfer effect on MC handling. Granted there's more to it than this, and automobiles are different, but the physics are similar.
Back in the 70's we bought an old convertible to restore. It did not run so we loaded on to our car trailer facing backwards because that was the easy (aka Young & Stupid) thing to do. The tongue weight was all screwed up, and we received a unpleasant lesson on the subject while traveling down the interstate on the way home.
Kevin
Ulysses S. Grant
Old 07-24-2009, 10:36 AM   #12
Lumatic's Avatar
1967 24' Tradewind
1975 31' Sovereign
Estancia , New Mexico
Images: 16
Might be a rumbleseat for the mother in law.
Old 09-03-2009, 12:38 AM   #13
Spring , Texas
If attached to the frame of the Airstream would not think that it would cause frame separation. Anyone know for sure?
2007 international
Repairing Crack in Bathroom a Storage Space/Shelf tdoescher General Interior Topics 1 05-03-2009 02:22 AM
Wires in back storage compartment Baked Potato General Repair Forum 4 03-26-2008 08:35 PM
Motorcycle carrier on back of 25' Excella danlesr Towing, Tow Vehicles & Hitches 23 05-29-2007 10:19 PM
Back from winter storage! RedSHED Winterizing, Storage, Carports & Covers 5 03-10-2007 02:03 PM
Bathroom storage for any recent 25' - 2003 Classic Pahaska 2001 - 2005 Classic 3 05-06-2005 09:30 AM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
