02-23-2015, 11:05 AM
Yertle01.com
2006 22' International CCD
Estes Park
Newbie Question: On the Level
I'm struggling with how best to level a twin-axle. I've considered purchasing those plastic Lego thingies, but can't imagine how to easily pull or back up both wheels onto them. And I've thought about buying three or four 1"x6" six-foot long boards to use, but that seems cumbersome and space hoggish. I'd appreciate hearing how most of you handle this, and thank you in advance.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
02-23-2015, 11:14 AM
2008 25' Classic
Full Time
I bought two sets of 10 Lynx blocks. I set the blocks in between the tires and either ahead of the front or behind the rear tire and pull or back up onto the levelers. If I need more height then I have to add more levelers hence the reason to buy two sets of 10. I may switch over to Anderson levelers.
3604 - Camper Leveler
Kelvin
02-23-2015, 11:20 AM
1976 31' Sovereign
Missouri City
First thing what situation would you need to level the trailer. Right to left, front to back on a hill unlevel ground. All of these can have an effect on how you level the trailer. Backing or pulling on leveling blocks or boards is a simple task just place the blocks or boards in front of or behind the wheels and back up or pull forward. But different techniques apply based on the reasons you need to level and how much.
Don Hardman
1976 31' Sovereign
02-23-2015, 11:52 AM
Yertle01.com
Estes Park
Kelvin, thanks for the suggestion on Andersen levelers. Before you make the switch, you might wanna read the comments on Amazon. In theory they seem great. In practice, not so good.
TRizzuti.com
Yertle01.com
02-23-2015, 12:16 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I have used boards for years - 8" wide (too hard to hit correctly) 10" wide same issue, then went to 12" boards. If I'd wanted to be a contractor I would be getting paid to use that wide a board. However, I still carry a couple cut down to 48" just in case. I switched to legos a couple of years ago and they are easy to "hit" when backing or rolling onto them forwards (my co-pilot) places them OR I do and the other drives on until told to stop. Then use them under the four outriggers as well. Nice invention.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
02-23-2015, 12:21 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
02-23-2015, 01:34 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Or, a short piece of 2x10 nailed or screwed to a 4x4 ... high school physics; remember the inclined plane!
02-23-2015, 02:08 PM
Common Sense
Over the years I've used just about all of them, and have recently (last year) bought some of the Andersen Levelers, and I think they're great. By far the best I've ever used.
Regards,
Steve
02-23-2015, 03:26 PM
1976 31' Sovereign
Oswego
I have used 2/8 boards for years cut long to span both axles or short for 1 axle stack if needed. I place boards next to wheels either pull forward or back stopping when clear end, wife slides over then I pull or back onto them, have same size short place under stabilizers I paint them blue so if get muddy or dirty just hose them off besides they look better than plain wood that gets stained and ratty looking, also use chocks like semi trailers use , you will not be able to move AS with them in place. If they slide when stacked use others to ramp up on leveler stack.
02-23-2015, 03:37 PM
Oswego
I like the Andersens....except on soft ground
-Rich-
02-23-2015, 03:58 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We've been using the "leggos" since the beginning. They light, adjustable, and easy to deal with. We have used these to change tires on the highway four times over the years.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-23-2015, 04:11 PM
Oswego
I always used Legos. But with a long trailer and dual axles, I found there were occasions where I needed in excess of 3 sets in some sites that were substantially off level in both directions. 3+ sets took way too much room in the rear drawer, so I now carry the andersens and one set of legos. This combo leaves a lot more room in the trunk and accommodates those rough sites.
-Rich-
02-24-2015, 10:24 AM
2012 31' Classic
Golden Valley
Combination of 'legos' and boards. But the boards we use are the plastic decking type. Very durable and don't hold moisture.
02-24-2015, 10:58 AM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
I have legos I rarely use. Usually I stand back check front to back level and side to side and then I decide where to put my pillow for sleeping. Has worked for over 20 years.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
02-24-2015, 11:59 AM
2019 27' Globetrotter
Missouri Valley
, Iowa
Terry,
I made a pair of wooden level blocks with 3 steps. The base piece is a 2X8 about 27" long with a 45* bevel on one end. In the middle of the this board is a piece of 1X8 about 8" long. The last piece is another 2X8 also 8" long fastened flush at the rear of the long base piece. We also stage these boards as Featherbedder describes. On occasion we need more height and when that happens I put another beveled 2X8 18" long on the stepped piece.
Dan
02-24-2015, 04:23 PM
Yertle01.com
Estes Park
Thank you all for the suggestions. It sounds like folks are all over the map with this. Lots of innovation, it seems.
TRizzuti.com
Yertle01.com
02-24-2015, 07:01 PM
Biloxi
, Mississippi
I use the Andersen leverers and think they are the best thing since sliced bread. Easy to use, set up and adjust. I trailer alone and find them much easier to use than the blocks. A big plus is their ability to lift one axle to change out a flat.
MICHAEL
02-24-2015, 07:12 PM
2012 27' Flying Cloud
W
, New England
I like the Andersen levelers too. You can get the exact amount of level you need from 1/2 to 4 inches. Quite ingenious design.
02-25-2015, 08:49 AM
Yertle01.com
Estes Park
I like the idea of the Andersen levelers but am trying to figure out if they'll fit between the wheels. My AS is a 2006 22' International CCD. I see where Michael has a 2006 23' Safari SE and is happy with the Andersen's. Does anyone know if the distance between the wheels of our campers is the same?
TRizzuti.com
Yertle01.com
02-28-2015, 11:00 AM
2015 25' Flying Cloud
Hahira
, Georgia
What is wrong leveling with the stabilizers?
From my Pecan Tree
