Old 07-11-2011, 07:25 PM   #1
kipper's Avatar
2006 19' International CCD
Hatboro , Pennsylvania
Red face Its me or the Bambi
We have had our 2006 Bambi 3 weeks and its keeping me working . We bought it at a dealer 400 miles away , when we got it home the shower head leaked and I replaced the Moen cartridge , not that easy because the clip that holds the cartridge in was on the back side of the wall , so out came the divider wall between the shower and the toilet , all back together now . Went away for 4th of July , noticed soft spot in the floor to right of entrance door ,got home and up came the vinyl floor and replace a 7 inch square piece of sub floor and track down the leak , looks like the belt line trim leaked and now waiting for rain to see , today it was repack wheel bearings that I guess the dealer had no time to do because they did'nt do it , good thing I looked . So my three day weekend is over and back to work Tuesday , cant wait . But I still think it was worth it .
kipper is offline   Reply With Quote
Old 07-11-2011, 08:01 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Bummer that you have to put so much labor intense time into your new purchase. But once you get it the way it should be, you'll be happier. Proper maintenance along the way to keeping it more problem free is the key to enjoying the Bambi (or any trailer). It appears that may not have happened before you got it.
TB & Greg and Abbey Schnauzer
#3954
Old 07-12-2011, 08:51 AM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
kipper,
Did you find repacking the wheel bearings an easy or daunting task? I need to do (or have done) ours. Watching the YouTube videos I feel uneasy about all the possible things I could do wrong. I'm pretty handy with tools, but I'm a woodworker. All that pushing, punching, hammering, and grease makes me nervous. Shall I try it?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-12-2011, 11:54 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Hi Greg.
I can not really tell you if you should try it or not. I did just finish doing mine last Wed. and we just got back from a 1200 mile trip today in which they worked fine.
I bought a tube of wheel bearing grease and the little Liesle hand packer mentioned in some other threads. I used to do boat trailers and a couple of car front wheel bearings 25 or so years ago so not a total beginner at it. Reason I decided to do it myself is that it seemed very hard to make an appointment at camping world and to take the trailer to them on the time frame I had to work with. And I was afraid to take the trailer out again without checking them.
I did it one wheel at a time. I use a little hydralic jack AND A SPECIAL MADE SADDLE to fit under the frame right by the wheel. You could use lynx blocks or one of the pull up jacks and do one wheel at a time with the tow attached. or find the trailer jack points and jack it there.
I took one wheel off and punched out the seal and took a bearing and a seal down to NAPA. Bought a bearing set all together sealed on a card and 3 more seals, expecting to replace the seals and to have an extra set of bearings. Went home and washed the bearings in kerosene to inspect them. The grease around the bearings looked fine, but the grease actually in the bearings was black. When it washed out the bearings felt gritty, though they looked fine. I just made the decision that it was easier to pay 35 bucks a wheel for new ones that to try to decide which of the old ones were usable. (The old bearings were put in 4 years and 40000 or so miles ago and not checked until last week). The NAPA bearins looked okay and were made in Mexico. Most of the old bearings were USA, but a couple of them were China.
Hardest part is getting the old seals out of the hubs. Used a 1/4 inch pin punch to drive out the old races. Used a old piece of 1" by 1/4" aluminum bar to drive the races back in.
Reassembled everything and adjusted the nut. Then adjusted the brakes (mine are not self adjusting.) the brake pads were wearing evenly and had enough thickness for at least another year. One set of brake wires were broken so I was only using 3. glad I finally checke them.
Cost about $170 for the bearings and grease and packer.
camping world here does it for $225 labor but of course will add parts to that. when I called them they automatically factored in brakes and the estimate was a bit more than $600. When I had them done at airstream it was $1000 for new brakes and bearings but that might have included drums. not sure. It does not save a whole lot of money to do it yourself. basically you save about $200 plus the retail difference on the parts if it needs brakes. For that I judge it pretty much not worth it just for the money, but time and scheduling and confidence in the finished job counted for me.
It took me 8 hours spread over 2 days and I was very dirty. My suggestion is that unless you are sure you want to get that dirty and sore (bending down and crawling under the edge of a trailer is hard on folks as old as me) I think you would be better served by just taking it in and getting it done. Grease is not good for a woodworking shop either. I am still cleaning my bench and tools. I know a fair number of airstreamers and there are only 3 or 4 of us who have done it ourselves.
Old 07-12-2011, 12:16 PM   #5
2011 31' Classic
Images: 8
OK, that's all I need to know. I'll be calling my shop this afternoon <grin>.
Old 07-12-2011, 02:36 PM   #6
kipper's Avatar
Hi Greg , packing the wheel bearings is no big deal , it cost me a tub of grease , 5.00 and wheel seals 20.00 and an 2 hours time , yea its messy but no big deal . Also yo have one more axle . I think its good to be able to do the work yourself , you know its done right .
Kipp
Old 07-12-2011, 02:45 PM   #7
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I did mine also, not too bad. Only took about three hours.
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 07-12-2011, 02:46 PM   #8
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Its you
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 07-12-2011, 02:54 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Thinking outside of the Box!
In Virginia we have to get trailers inspected annually. Only one RV dealership within 30 miles is also an inspection station, but I found a car repair shop that also inspects trailers... and lo and behold they'll do the wheel bearings MUCH less expensively than any RV shop including the mothership. There's also a truck and trailer store that primarily sells utility trailers which will also do this messy chore correctly and reasonably.
Think outside of the RV Box!
Paula
Old 07-12-2011, 05:37 PM   #10
kipper's Avatar
my keyboard is missing the u key
Old 07-12-2011, 07:18 PM   #11
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
You can use this tool to easily remove the old seal. The KD or Lisle brand is under $10 at Sears.
Name:   Lisle Seal Puller.jpg
SilverCottage is offline   Reply With Quote
2006 international
Value 1963 Bambi Ciciolina Trailer Values 28 07-12-2011 07:35 PM
Bath outlet in 2011 Bambi Int'l Signature YNP Electrical - Systems, Generators, Batteries & Solar 0 07-04-2011 02:43 PM
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
