Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2006 - 2010 International
Old 05-14-2010, 04:44 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Fridge... Should I worry?
On my 2010, We haven't taken the Stream out for about 2 weeks and always let the propane or plug run the fridge while stored in the driveway. No telling when we will just get up and go. So some items are left in the fridge. Well, for the past 4 days the Stream has been unplugged and running on propane. I went out yesterday and opened the fridge and it was warm inside. So I walk to the front of the stream and look at the propane bottles and the indicater is green. I then go inside and light the stove, all systems are a go...well minus the fridge. So I decide then to plug up the stream to the 110 outlet in the garage and everything is now working like it should.
Anyway, off to go camping now and I will look at this through my phone.
Thanks in advance for any tips or suggestions.
SHane
https://i52.photobucket.com/albums/g...h_postcard.jpg
Tow Vehicle" 2023 F250 Azure Gray!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 05-14-2010, 04:50 PM   #2
2010 31' Classic
Mobile , Alabama
Send a message via AIM to Greg N Send a message via Yahoo to Greg N
Well it takes more than propane, it also has to have 12 volts to run too...The fridge that is...So if you where unplugged long enuff from shore pwr. then the fridge wont work when the batts. run down... I'd be more worried bout spoiled food that mite make ya sic...
Greg
Greg N is offline   Reply With Quote
Old 05-14-2010, 10:05 PM   #3
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
So when I hit store.....it killed it. Sound feesiable?
Shane
TAC ID TX-1432
Old 05-14-2010, 10:10 PM   #4
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Why do you use the store switch? Your fridge is probably fine then. But you only need the store switch when leaving your Airstream in storage, I think. Even then the batteries can eventually run down. We keep the Airstreams at home and never use the switch and rotate from battery to electric.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 05-14-2010, 10:10 PM   #5
2007 25' Safari FB SE
Blaine , Washington
That's exactly what happened. When you turned off the batteries and unplugged from shore power you killed the fridge even though it was on propane. You need to leave the batteries on if you are not on shore power. As with most things, I learned this the hard way.
John
Relentless is offline   Reply With Quote
Old 05-14-2010, 10:38 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, If your refrigerator control is like mine, you need to set it in the auto[matic] mode so it will change from a/c to gas when you unplug your trailer from shore power. If you set it manually to either gas or a/c it won't change over. And as you have just learned, your refrigerator needs 12 volts for the control panel to work.
Name:	IMG_0713 (Large).JPG
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
2010 international
Pipe vent covers storing water... should I worry? ronstory Roof 12 10-01-2008 01:38 AM
should I worry? ostapbender Cleaning, Stripping & Polishing 3 06-19-2007 06:28 PM
DC Fridge Over59 Refrigerators 18 06-13-2006 01:43 PM
New fridge Greywolf65 Refrigerators 3 04-26-2006 06:53 PM
Why worry? Pschoerrn Off Topic Forum 1 05-15-2005 01:36 PM
