Old 08-29-2013, 07:50 PM   #1
gecko's Avatar
2009 28' International
Pacific Palisades , California
Bedroom Curtain Supplements
We have a 28" International Ocean Breeze, and find that it some location, the lined curtains cannot block out enough light--usually a high intensity park light just outside, for example.
So far, our best solution has been functional, but pretty tacky--we've patched together silver auto windshield covers to fit between the curtains and the window, silver side out of course!
Has anyone come up with a more elegant solution? We'd rather not re-line the curtains with darker lining for several reasons--letting light in during the day while closing the curtains for privacy, the look of the coach from the outside at night with the palm trees shining out, etc.
Thanks!
gecko is offline   Reply With Quote
Old 09-04-2013, 06:53 PM   #2
Silverbee's Avatar
2012 25' Flying Cloud
Fuquay Varina , North Carolina
If you sew you may want to consider a fabric called "Dim Out". It blocks 50%-75% of light depending on the strength that you buy. I am going to make backings for my curtains to be used when I want to block sunlight or nightlights that are too strong. I will not reline the curtains just make a backing slightly smaller that the curtain and attach with velcro. I will be using mine primarily when we are storing our Airstream under our shelter and sunlight hits the rear bedroom windows. I want to protect the curtains from damaging UV rays.
Mrs. Silverbee
Silverbee is offline   Reply With Quote
Old 09-04-2013, 06:58 PM   #3
dkrug's Avatar
2012 30' International
Deford , Michigan
I plan on doing something similar to Silverbee. I can't sleep with much light. I plan on cutting up a curtain from squall mart that blocks light.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 09-04-2013, 07:56 PM   #4
Gene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
This is not elegant, but does insulate better when it is cold or hot. Reflectix has 2 shiny sides with something like bubble wrap between the foil. We Velcro'ed it each bedroom window and it keeps the room pretty dark. Also works on the fan and skylight openings, or anywhere else. With a FB, no one can see it easily with the tinted rock guards. RV stores have it and I've seen it at Lowe's.
If you're going to do something simple and practical, this works.
Gene
formerly posted as CrawfordGene
Old 09-04-2013, 11:14 PM   #5
gecko's Avatar
Thanks for checking in, folks! We do already have the silver one side/white other side auto windshield sunshades cut to size and held in place with velcro, but it's pretty funky looking. Wouldn't permanently re-line the curtains because with our Ocean Breeze, the curtains are very special both when closed for privacy during daytime and the outside light lights them up, and when viewed from the outside at night with the inside lights backlighting them.
If nobody comes up with a better idea, I'm currently shopping for some of these that are a bit better fit so I can make them prettier. Two years of using them with velcro has also taught us what to do and not to do with velcro! Turns out that Dollar Stores standard $1.00 windscreen sunshield is pretty much the perfect fit for a 28' International's back window, so i'm set there. Just looking for the taller ones required for the side windows. The hunt is on!
2009 international
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
