Old 11-29-2012, 10:46 PM   #1
2010 25' FB International
Woodside , California
Amateur hour. Forgot electrical cord.
I forgot the electrical cable that plugs into the airstream. Do most rv dealers carry that plug or am I s.o.l? Is there a bypass to just plug in a 110 v cable?
RLemmens is offline   Reply With Quote
Old 11-29-2012, 10:55 PM   #2
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
I don't know about RV dealers, but the end that plugs into the Airstream is a standard NEMA L5-30. This plug will not have the locking ring but is the correct connector. I just brought one at an electric supply house and put it on the end of a standard extension cord to plug into my generator so I don't have to get out the heavy Airstream cord to use it. If you are near a good electrical supply you might try that.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 11-29-2012, 11:02 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
An RV dealer should have one.
Heavy Duty 30-amp 10/3 STW Cord, 25
To plug it into a normal outlet.
15 Amp Male to 30 Amp Female Adapter - Intersource Enterprises D11-158 - Electrical Adapters - Camping World
daveswenson is offline   Reply With Quote
Old 11-29-2012, 11:04 PM   #4
SStar's Avatar
2004 28' Classic
Midland , Texas
adaptor
Walmart usually has the adaptor from 3 prong 30 amp to a regular 3 prong 110 volt.
SStar is offline   Reply With Quote
Old 11-29-2012, 11:41 PM   #5
crisen's Avatar
Fairbanks , Alaska
Originally Posted by daveswenson View Post
When I tried this link it just went to a 30 amp extension cord. That won't plug into an airstream if it has the twist lock style at the trailer. I am not familiar with the older models but my 2012 has the NEMA twist lock I quoted earlier.
Rick
Old 11-29-2012, 11:42 PM   #6
I got a three prong but it doesn't fit because the third prong isn't cylindrical.
Old 11-30-2012, 12:13 AM   #7
You're right Rick, I thought that cord had the L5-30 end.
Dave
2010 international
