Old 06-02-2011, 10:58 AM   #1
2010 27' FB International
Simi Valley , California
Aluminum Tail Light Housing Corrosion
Hi fellow AS'rs,
We recently noticed that the aluminum housings around our tail lights have some corrosion in the finish. We've tried a couple of cleaners recommended for aluminum with no improvement. The local service center recommends soaking them in paint remover overnight to remove the clear coat, sanding them with high grit wet sandpaper, then applying new clear coating.
We're just curious if others with late model AS's have encountered this. Apparently it's somewhat common on trailers spending much of their time near the ocean, but that's not us. It's only spent a couple of weekends at the ocean and we always wash it when we return. Otherwise it's kept in a well sheltered area on the north side of our house.
We're perplexed .
Thanks in advance for your thoughts on the matter!
Shelly
Shelly M is offline   Reply With Quote
Old 06-02-2011, 12:47 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You are not alone...
More information in this very long thread:
http://www.airforums.com/forums/f142...ams-31743.html
Richard
Old 06-02-2011, 01:05 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Lucy's are pretty bad, too. So far, I am just living with it.
Please let us know what you do and how it turns out.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 06-02-2011, 07:30 PM   #4
"Cloudsplitter"
You could use the same solution I did for the Battery Door Frames. Lots of elbow grease though.
http://www.airforums.com/forums/f142...tml#post607273
http://www.airforums.com/forums/f142...tml#post606944
"You don't know where you've been until you leave, enjoy life" RLC
Old 06-02-2011, 07:41 PM   #5
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I've got it on my 06 Bambi and want to tackle it this summer. Keep us posted on your results, I think I'm going to go that route.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 06-02-2011, 08:21 PM   #6
HCR
HCR's Avatar
Livingston , Full time traveler
I have it on my '06 Safari and don't care. It's a very minor issue given the severity of the others I've encountered, leaks from rear bumper, rear window, AC and on and on.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 06-02-2011, 08:46 PM   #7
Westfalia's Avatar
Some Place with a German Name , Texas
Images: 35
Send a message via AIM to Westfalia
Yes, my 08 has this ok both lights. I will eventually remove each housing, have them media blasted and then powdercoated.
Westfalia is offline   Reply With Quote
Old 06-02-2011, 09:37 PM   #8
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
We have it on our 2005 Safari. I also noticed some spider veins around the clearance lights when I was washing the trailer last week. Just squiggly little veins on the aluminum that wouldn't wash off. I'm certain something will remove them, but I don't know what. JC
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
rustyrivet is offline   Reply With Quote
Old 06-02-2011, 10:09 PM   #9
dekew's Avatar
Culver City , California
Yep- we just noticed this on our 2010 int'l. Luckily, we're at Alumapalooza this week, so it shouldn't be difficult to find someone who knows something about this. I'll ask around and report back.
Deke, Tiffani, and Lucy the Cattledog
2010 27FB International CCD - "Big Weas"
2012 Ford F-250 6.2L V8 Crew Cab
Follow us on Weaselmouth.com, Connect with us on facebook and twitter!
dekew is offline   Reply With Quote
Old 06-02-2011, 10:17 PM   #10
2005 22' International CCD
Aliso Viejo , California
Shelly,
Yours are pretty bad for being only a year old. Have you tried the dealer for a possible warranty claim? I'd rather see Airstream be accountible for this than you to spend time redoing them on a new trailer. That shouldn't happen that fast. Pat
Davern1 is offline   Reply With Quote
Old 06-03-2011, 07:32 AM   #11
"Cloudsplitter"
Just use the word corrosion in the search bar above, a lot here have experience with it.
aluMATTER*|*Aluminium*|*Forms of Corrosion*|*Filliform Corrosion
Old 06-03-2011, 08:05 AM   #12
DougZ's Avatar
1972 27' Overlander
Venice , Florida
The tail light housings on my 1972 Overlander look better than that! What gives?
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 06-03-2011, 09:14 AM   #13
AS'rs are the best!! I so appreciate all of the comments and information. You helped find some existing threads that I didn't see and even shared at least one other fix.
I agree that it is a relatively minor issue and I feel fortunate that it's not as bad as many of you have experienced. It hasn't affected any body panels. But if we can fix it, we will. I want her to live forever and as original as possible!
On the warranty comment, we discovered it about a month after the 1 year warranty had expired. I will contact the factory. It can't hurt, right?
THANK YOU!!
Old 06-03-2011, 10:07 AM   #14
2010 27' FB Classic
N/A , Texas
Shelly, I believe all 2010's have a 2 year warranty.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Old 06-03-2011, 10:39 AM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have the same issue with my 2007.
Old 01-02-2012, 11:28 AM   #16
Niagara2011's Avatar
2011 28' International
San diego , California
We noticed it on our 2011 just a few months after purchasing. Apparently it's not under warranty, as I requested as fix it. They suggested to use corrosionx t9 and were using wulbernize. Based on our research, you should apply these products asap Ne try to limit the corrosion. Hope it helps!
Niagara2011 is offline   Reply With Quote
2010 international, aluminum, taillights
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 05:45 PM
Replace Tail Light Bezel on 1971 Safari pickerdd Lights - Interior & Exterior 2 05-31-2011 07:20 PM
Rear light housing seal--how? OB Bambi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2011 04:33 PM
