Old 11-14-2007, 08:25 PM   #1
yakman's Avatar
2007 25' International CCD FB
Gahanna , Ohio
'07 FB CCD Side Bed making question.
Hello,
We were able to spend a couple of nights in the new trailer this fall but wondered about making the bed opposite the sink on the roadside with the pull-out. We pull the slider out and use the long back cushion to fill the space, however it doesn't really fill the space. It's a little bit too wide and rests on the lip of the pull-out tray. Therefore the hallway side of that bed has a slight incline to it. Is this what everyone else has experienced?
Our little one hasn't complained about it and we figure it will keep her from rolling onto the floor but it just seems like that cushion should fit into that space a little better.
Cheers,
Doug
yakman is offline   Reply With Quote
Old 12-15-2007, 01:27 PM   #2
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Yes mine is like that too. I would think Airstream would do a better job of fitting and standardizing the cushions too. They can't quite follow curves along the dinettes either. I store placemats, mylar sheets in place of cutting boards, and other thin flat things under the cushions, and my yard stick just next to the lip. My stuff may make the cushion slope more gradually? However the cushions separate and shoot all over the place. If the lip fit the extended depth it would be nice. Do you think we can possibly figure a fix when the AS engineers could not?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 02-18-2008, 03:14 PM   #3
Corbett , Oregon
We have a '07 23' International that has the same problem---what the heck we're they thinking. Short of custom making something to fit the slide-out (more to store), I haven't figured out a simple solution.
If you hear of a good solution, pls let me know.
Lochsa
Lochsa is offline   Reply With Quote
Old 02-18-2008, 03:27 PM   #4
Lapeer , Michigan
Brad has a 23' International and we are using a Hacksack system since the size matches the space better than the Travasack. Leisure Industries We have used it on the corner bed and on the slideout lounge. The winter side has more batting and makes a nice cover for the cushions with a tiny tuck between the cushions and walls to secure it. It may shift a bit but once inside you are snuggly and can roll up the whole shebang and stow it. If you feel creative you can face it with covering of your choice and make some alternate velcroed sheets to please your fancy. Add a nice throw pillow or two and voila'.
Caroljb
photography
2007 international
Making the bed in the kitchen Sparkygus 2006 - 2010 International 5 05-17-2007 05:50 AM
Making the bed in the corner...Help! wildwoodrver Our Community 12 11-16-2004 12:57 PM
Side Couch/Bed Stabilizing Argsy26 All Argosy Trailers 2 08-03-2004 08:29 AM
Side Dinette /converting for bed linc54 Interior Restoration Forum 0 01-20-2004 10:45 PM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
