Old 08-16-2017, 11:51 AM   #1
BambiCamp's Avatar
2017 16' Sport
Adirondacks , New York
Zamp plug
So i'm electrically challenged (2017 Sport 16) ... but wondering.... if the Zamp plug could be used with appropriate connector for 12 volt power out ... to run tire air compressor, dc string lights and other 12 volt stuff? All I find is a fuse in the line from the A frame Zamp plug to battery .... thanks in advance for advice
BambiCamp is offline   Reply With Quote
Old 08-20-2017, 05:11 PM   #2
2017 22' Sport
Calgary , -
Sure could but always be cautious of having power on the exposed side of the plug. Also make sure to check polarity as the Zamp plugs are reverse of normal CES connections.
robinjen is offline   Reply With Quote
Old 08-20-2017, 06:45 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
As long as you don't do:
1) Get the polarity reversed
2) Pull to much current
You should be fine.
uncle_bob is online now   Reply With Quote
Old 08-20-2017, 07:23 PM   #4
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Yep I had to make an adapter. There's a post on how to do that but basically ya gotta get a 2 pin, cut it and resplice it so it swaps polarity. Then plug your stuff into that.
TravlinMan is offline   Reply With Quote
Old 09-02-2017, 10:22 PM   #5
dasams's Avatar
Palm Desert , California
^ This. My Zamp plug was 'normal' polarity so when I plugged in my Zamp suitcase it wouldn't work. I called Zamp and they sent me the correct 'reverse' polarity plug. Now I have one of each
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Zamp Plug Reverse Wired? dasams Generators & Solar Power 6 11-16-2016 01:09 PM
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 04:44 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 06:24 PM
