Old 07-05-2017, 05:03 PM   #71
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Series can be better if you've no shade issues, and the higher voltage from panels in series can reduce DC losses en-route to the controller if your cables are a little thin. (This assumes your controller can handle the higher voltage.)
Parallel can be better if one panel gets shaded, but the lower voltage means that in general you should try to use thicker, heavier gauge, cables to reduce losses between the panels and the controller.
With shade you lose output either way, but with parallel, if one panel is shaded the other panel still produces full output. With series, one shaded panel will more severely reduce total output.
Rocinante is our 2014 International Signature 27FB
Old 07-05-2017, 08:45 PM   #72
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Thank you, that makes sense. My cables are all 8 guage on the trailer and between panels, though the controller I use for the truck is 12 guage but I only use 100 watts for that.
I'm gonna have to do a bunch of experimentin with my 2 controllers and 4 panels.... it's fun though!
TravlinMan is offline   Reply With Quote
Old 07-08-2017, 09:29 AM   #73
Traveler
TravlinMan's Avatar
Staunton , Virginia
Well I have to say I'm very impressed so far with these renogy eclipse panels. They are so much lighter and easier to move around than the portable one is. I'm glad I got these and not flexible ones cause these are easier to make legs and stands for. I'm still testin output but they seem to output more amps than my old 100w suutcase, too. Great deal for 175 each.
Old 07-16-2017, 11:18 AM   #74
Traveler
TravlinMan's Avatar
Staunton , Virginia
Over 8 amps from 1 panel under clouds today well before noon. Pretty good I think.
Zamp 160 watt portable solar dznf0g Generators & Solar Power 20 03-02-2016 07:10 PM
160W Portable Solar Kit (Zamp) chrij0ir 2009-2015 Flying Cloud 1 02-22-2015 12:53 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
