Old 08-31-2011, 05:28 PM   #1
pol
1995 30' Limited
1995 31' Land Yacht LE
Seattle , Washington
Unhappy Yacht will not take shore charge
I purchased a well maintained '95 Land Yacht LE 30 and drove it home one week ago. Once home I started the generator, let it run for a few minutes, and shut everything down. This morning, one week later, it did not have enough charge to start the engine - just one short rrrrr. The generator would not start either - it clicked like a low battery usually sounds. I plugged the main cable into shore power about 10 AM and checked to see it was powered up. About noon I checked and there was no charge. I switched the "dock" switch into the alternate position (as there is no mention of it's proper position in the manual). At 3 PM there was still no charge.
When plugged in to shore power the test switch indicates both battery systems are up. When disconnected, there is not enough power to get a reading.
Any thoughts?
pol is offline   Reply With Quote
Old 09-01-2011, 05:30 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....
pol,
Probably best to start simple, I would remove the batts, charge completely, let sit for a few hrs and test.
Check all breakers & test for parasitic draw.
KISS usually works.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-02-2011, 10:06 AM   #3
pol
1995 30' Limited
Yacht batteries
Bob,
The batteries were old and tested bad. I replaced them.
thanx
pol
Old 09-02-2011, 01:25 PM   #4
pol,
Dad was rite again....KISS does work.
now get out and enjoy
PFC
RLC
Shore power requirments for trailers Mrcrowley Generators & Solar Power 21 08-02-2017 05:20 AM
Battery stopped taking a charge pinktrailer Batteries, Univolts, Converters & Inverters 3 01-16-2017 04:34 PM
Airstream Land Yacht Diesel Repo Slide out Wash/dryer SAirstream Land Yacht Diesel R eBay Watch Airstreams on eBay 0 08-04-2011 07:10 PM
'99 Land Yacht WB masseyfarm Land Yacht/Legacy Motorhomes 0 07-07-2011 10:34 AM
Charge line breaker stuck open AirHome Batteries, Univolts, Converters & Inverters 3 04-13-2011 10:18 AM
