Old 01-12-2007, 07:21 AM   #1
2004 22' Safari
Canyon Country , California
Question XM Radio Antenna Installation HELP !
I have a 2004 22’ safari that has a Sony Stereo Head that is XM ready but the problem is getting the antenna on the roof with out drilling a hole in my nice dry trailer . I think I have figured a way to the roof but I need a view of were the bath room vent stack is located. I think it is behind the soft wall next to the sink but I am not sure. Does anyone know or have a picture of this area? If I can get into the vent stack there is the perfect route for the antenna wire any ideas?
whurley is offline   Reply With Quote
Old 01-12-2007, 07:55 AM   #2
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
K-I-S-S
Run the wire through a window and close it.
I wouldn't drill my roof...
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 01-12-2007, 09:44 AM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
Interesting idea. Attach a little angle bracket to the top of the vent and put the receiver on that? It will not stick to the roof. Those new trailers hide all the mechanicals pretty good. Call the factory, I'm sure they can help. Or have the dealer do it.
Over59 is offline   Reply With Quote
Old 01-12-2007, 10:21 AM   #4
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
XM makes a marine antenna that can mount on the side.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 01-12-2007, 12:03 PM   #5
2004 22' Safari
That was the best way I could think of. I was thinking about the window but I don’t want wires hanging out all over. But if I run through an already existing opening like you said mount a little metal plate you have a clean install ion without making any hole in the skin of the trailer. I called a stream and the were no help at all. So I guess I will have to open it up and take a look.
Old 01-12-2007, 03:08 PM   #6
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Have you considered going down through the floor and along the frame and back up through the vent for the fridge?
Family of Disney Fanatics
WBCCI# 4821
Old 01-12-2007, 03:30 PM   #7
2004 22' Safari
That won’t get me there the fridge vents out the side of the trailer. The only openings in the roof are the Vent for the bathroom, Vent Stack, Roof vents, A/C, FM antenna and TV antennas. I have considered removing the FM antenna but I lose local programming.
Old 01-12-2007, 06:01 PM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Aftermarket onglass XM antennas are available. I believe a company named Terk makes one.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-12-2007, 09:30 PM   #9
Clayton , North Carolina
Come out from under, fashion a bracket on the tongue for it. I've done quite a few XM/Sirius installs and they don't have to be on the roof.... especially if you're not moving (you don't ride in your trailer do you? ) You can trial it just running it out the front window first.
Paul NC is offline   Reply With Quote
Old 01-13-2007, 06:28 PM   #10
R&SZinser's Avatar
Yorktown , Virginia
XM Antenna
Here's a link to a thread I started about a similar issue.
XM Antenna
I ran the antenna thru a small hole in our old Fantastic Fan. Worked great under the plastic dome even when closed.
R&SZinser is offline   Reply With Quote
Old 01-13-2007, 09:34 PM   #11
XM Antenna
I like that idea even better! On my wife's former Beretta I put the antenna on the metal defrost vent on the dash (looking up through the windshield)
"Cats are intended to teach us that not everything in nature has a purpose." - Garrison Keillor
Old 01-13-2007, 10:44 PM   #12
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
I run ours down the wall from behind the front overhead cabinet/AV bay out the front window and up to the roof where I have it velcroed to the top. Works great with no drilling. I did have to unscrew the screen window to get the antenna connector through.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 01-15-2007, 07:34 AM   #13
2004 22' Safari
XM Antenna
This is what I was wanting to do in the first place but I did know if there was enough gap to run a fish tape in there. Thanks this was what I was hoping to find out.
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 10:17 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 01:04 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
