Old 10-23-2011, 10:57 AM   #1
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Wiring to ceiling fan colors & source question
I'm installing a ComfortAir fan in place of the front vent in my 2000 Bambi. I've pulled the old vent out, and I found a set of wires in the ceiling, presumably there for an optional fan. Yellow and Green. Okay, that celing power circuit is yellow wires. Is the green a ground? All the grounds are white, I thought. Secondly, checking with a voltmeter, using the working ceiling light nearby for a white wire ground connection, I can't find any power in either Yellow or Green. I guess I can tap into the light circuit to power the fan, but if the factory wires are there I should be able to use them, right? Sheesh...
robert claus is offline   Reply With Quote
Ceiling vent fan woodja Classic Motorhomes 4 07-29-2011 08:20 PM
30 amp/120v Wiring question... Trex Batteries, Univolts, Converters & Inverters 13 07-26-2011 07:47 PM
Replacing micro switch for ceiling fan roadglide04 Roof Vents, Skylights & Fans 1 05-17-2011 11:36 PM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
nagging wiring question DanielB 1973-1974 Excella 500 4 03-19-2011 06:00 AM
