Old 07-23-2011, 10:54 AM   #1
1968 28' Ambassador
Fairhaven , Massachusetts
Wiring Schematic for '68 Ambassador 29?
Can anyone help with some wiring plans for my 1968 Ambassador 29'?
Trailer is completely gutted all but the skins and wiring within. Thinking I will purchase a good generator to take care of most and plug in to outside power when needed. Planning to purchase ohm meter to begin resistance testing wires to see where they lead go???? Once figured, can I just buy small conventional appliances that run on 100V?
Love some input, just getting feet wet at this point
Silver Suckr is offline   Reply With Quote
Old 07-23-2011, 11:13 AM   #2
City power goes to the AC and outlets.
The 12 volts DC goes to the furnace, water pump, ceiling fans and all the lights.
How many circuits you need depends on how and what your going to change.
Generally speaking, each side of the trailer, has it's own 120 volt circuit breaker. The AC has the other breaker, and the univolt should have it's own 120 breaker as well.
For the 12 volt circuits, usually there a 4 of them. You will have to determine what currect drain, at maximum, you will demand from each circuit. Those circuits are usually rated at no more than 20 amps each. You should not design any cicuit that will demand more than 15 amps, at full load. The currect drawn for each 12 volt circuit will increase when the trailer is plugged into city power which increases the current draw.
The formula, for the DC stuff, is E=IR. E is the voltage, I is the current and R is the resistance.
Keep in mind, that when the univolt is working correctly, the 12 volts will increase to about 13.5 volts. Also, measuring the number of 'ohms" that each bulb has, is a waste of time, since the resistance increases when the filament gets hot.
Make you own schematic, before you start any wiring changes.
You will be glad you did.
Total wiring schematic joneslacey Electrical - Systems, Generators, Batteries & Solar 3 06-07-2012 09:20 PM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
67 Ambassador Wiring Diagram brownv1 Batteries, Univolts, Converters & Inverters 4 06-30-2011 10:06 AM
Wiring Teray Electrical - Systems, Generators, Batteries & Solar 4 03-06-2011 07:43 PM
A handy schematic snapshot from my furnace - 1970 Sovereign ranger_rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-18-2011 10:34 PM
