Old 04-29-2015, 02:38 PM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Wiring Schematic?
Hello All
I recently purchased a '71 Safari and have started restoration. The interior was completely gutted of all interior fixtures/ furnishings when I purchased it. I am looking for a wiring schematic for the trailer. I have wires poking out of the interior walls, only some of which read 12 VDC. I have white wires, purple wires, yellow, and black wires...even a few red ones for good measure. Also a diagram of the control center up front would be helpful, as all that is a mess too.
Your assistance would be greatly appreciated!
PS...My AC circuit seems to be intact, as all outlets are reading 120 VAC
bvcg1 is offline   Reply With Quote
Old 04-29-2015, 04:32 PM   #2
1980 31' International
Nixa , Missouri
Good luck, I have a 1980 interstate that the hot wire to the refrigerator doesn't have power. I have even called Jackson Center for information as to where it would be connected to get its power but they couldn't help, said a fire a few years ago burned their records.
I bet if the right person reads your post they have all the information you need. I am amazed at the information on here if the right person happens to read your post.
the frog is offline   Reply With Quote
Old 04-29-2015, 06:12 PM   #3
1969 31' Sovereign
Slinger , Wisconsin
i found this 12v wiring diagram from a '72 safari. shouldnt be too much different.
wiring-schematic-1972-20ft-safari-1972-airstream-wiring-diagram-23-25ft-jpg1200977pixels.jpg Photo by foxbrook78 | Photobucket
im going through the same thing right now with a 69 sovereign. the whole univolt system had been previously removed. 120v works. i just bought a battery over the weekend and hooked that up to the leads and it seems all of the 12v works, but i got lucky. im still going to relocate/rewire all of the main electrical and start fresh with all new re-wiring.
iceburg is offline   Reply With Quote
Old 04-30-2015, 07:41 AM   #4
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Thank you iceburg! That is very helpful! I just wish it were just a little bit higher resolution so I could make out the wire colors on the schematic. I will attempt to contact the person who posted the picture.
66 overlander wiring schematic. Airstray Electrical - Systems, Generators, Batteries & Solar 0 07-05-2010 11:01 PM
1973 Safari Wiring Schematic gmatteri Member Introductions 1 10-26-2009 06:56 PM
1975 Argosy wiring schematic argosy75 All Argosy Trailers 8 06-09-2008 06:08 PM
Schematic wiring diagram for Armstrong AC TR21-12, GO7series DMC Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2007 12:01 PM
Hello, looking for a schematic of the wiring in my Armstrong AC model TR21-12, DMC Member Introductions 1 07-10-2007 06:11 AM
