Old 05-19-2014, 02:54 PM   #1
1976 Argosy 26
Singer , Louisiana
wiring question
I have a 76 argosy 26 I have had it a year or so, it has a univolt that was replaced in 2007 and beside it the little fuse panel, has 5 fuses. I am trying to find out what the second fuse, goes to it blows when you put the fuse in, and it has a pink wire. I can see it goes around the wall behind the sink and toilet but not sure from their. Thanks for any input I took a picture I will try to post it later
Deere68 is offline   Reply With Quote
Old 05-19-2014, 04:08 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Call Jackson Center. Often manufactures use the same color code for several years. I assume Argosy and Airstream may have done the same.
2004 Excursion 4x4
Wiring question about ol' Jack Joe Swann Jacks, Stabilizers, Lifting and Leveling 4 11-18-2005 10:14 AM
hitch wiring question Craig Lights - Interior & Exterior 4 07-18-2004 06:09 AM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 12:46 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
