Old 07-13-2011, 09:03 AM   #15
Excella CM's Avatar
1978 31' Excella 500
Venice , California
In your second photo, some of the wires appear to be discolored where they attach to the breakers. this is usually due to loose connections. Make sure the screws are tight.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-13-2011, 09:09 AM   #16
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by TG Twinkie View Post
In the photo above, I noticed that you don't have "box connectors" on any of the wiring going into the panel. I would recommend installing them to prevent the wires from chafing on the edge of the holes.
There are arguements both ways on GFIC breakers. I believe the most important thing is to make sure the trailer is wired correctly. Routine checking and maintenance is important. As in the problem you had. The breaker GFI breaker did not and would not have prevented getting shocked.
Adding mores plugs, when done will add box connectors
Toastie
toastie is offline   Reply With Quote
Old 07-13-2011, 09:21 AM   #17
toastie's Avatar
1955 22' Safari
Point well taken ..............
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 08:49 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
